20 Most Recent
Razer Barracuda Gaming Headset Questions & Answers
When i turn the volume up or down i get a static
The static noise may be caused by dust! To clean it out spray some Servisol video 40 into the volume control and move it up and down. If it goes away it was just dust.
The mic is another thing. The only thing I can think off ist that it's got switched off somehow on your laptop. Or either the control panel slider for microphone input is set to low?
You can get Servisol from Radioshack USA or Maplin UK or that type of shop.
New razer headset..flashing green and not comnecting
If your Razer wireless headset is flashing green and not connecting to your Xbox One, there are a few things you can try:
- Reset the headset: Try resetting the headset by holding down the power button for 15 seconds until the light on the headset turns off. Then, turn the headset back on and try to connect it to your Xbox One again.
- Check the Xbox One controller: Make sure the Xbox One controller is properly synced with the console and that the batteries in the controller are fully charged.
- Check the Xbox One settings: Make sure the Xbox One settings are properly configured for wireless headsets. To do this, go to Settings > Display & Sound > Volume > Party Chat Output and make sure "Headset" is selected.
- Check for interference: Make sure there are no other wireless devices or routers nearby that could be interfering with the headset's signal.
- Contact Razer support: If none of the above solutions work, contact Razer support for further assistance. They may be able to provide additional troubleshooting steps or help you with a replacement if necessary.
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
