20 Most Recent
Sony Dual-Alarm AM/FM Clock Radio with Automatic Time Set Questions & Answers
The auto time set on my Sony Dream Machine is five
Have you tried to manually reset the time? I had the same problem. It got the the point where it was almost 20 minutes fast - I finally looked up the manual on-line and found instructions to manually reset it. It seemed to work just fine. I'm not sure if I have the same model as you do, but I'm sure the procedure is similar. I suggest you search the net for your manual.
How do you set the time on a log radio
you have to turn it all the way through to the correct time even if it is 23 hours and 55 minutes around. if you go a few minutes too far unplug the clock till time catches up then plug it in again
ICF C25
Most likely the clock radio is damaged beyond repair. If it can be repaired it may cost nearly a much as a new clock radio.
Clock Manuals
HelloI've the user manual to your Sony AM/FM clock radio. There are so many model numbers to these devcies. If you give me the exact model number [not the serial number], I'll search in my system library for that manual. If has,, if you send your email address to me by Fixya comment box, I'll send a copy of it to you, if I have it. If you need only a manual to sony AM/FM clock radio, send your email address to me now. I'll send you one[ user manual for SONY ICF-707 AM/FM clock radio. OK
