20 Most Recent LG Microwave Questions & Answers
0answers
0answers
The microwave will not start
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....Microwave Oven Basic Troubleshooting Tipsheatman101
4/18/2011 5:24:49 PM • LG Microwave • Answered on Apr 18, 2011
Not cooking. The tray turns, but no heating.
Basic Microwave Oven Troubleshooting Tips
heatman101
2/25/2011 3:44:38 PM • LG Microwave • Answered on Feb 25, 2011
My lg microwave is not
heatman101
[00000000000
2/25/2011 3:42:20 PM • LG Microwave • Answered on Feb 25, 2011
My glass tray want turn around. What can I do to
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
8/22/2010 3:11:52 AM • LG Microwave • Answered on Aug 22, 2010
Microwave wont heat up
Your signs point to a failed power tube. First though, does it defrost? If it does it is an electrical control problem. If it does not defrost, do the following.... With the power unpluged you may want to remove the outer cover, ( screws at back ), and locate a shiney metal box. That box is shielding for the power tube. Get the part # from the tube and replace. You could check price and availability at www.avnet.com . Make sure you replace all of the shielding exactly the way you found it. VERY VERY IMPORTANT!!!!!
12/2/2009 4:01:38 AM • LG Microwave • Answered on Dec 02, 2009
Want to buy a new rotating ring for my MS-214YE
Here you go old chap:
http://www.repairclinic.com/LG-Microwave-Parts
Cheers
11/6/2009 11:29:33 PM • LG Microwave • Answered on Nov 06, 2009
I have nationl mocro wave
If it's under warrenty guarentee, then take it back to where you bought it? If not, all you can safely do is to check the fuse, if OK, buy a new one. - sorry
7/2/2009 5:32:36 AM • LG Microwave • Answered on Jul 02, 2009
Squirel cage locked up on my furnace
Either the bearing has seized, or there is a bad connection on the terminal board where the wires connect to the motor.
I would spray the bearings with a good penetrating oil (I like PB's Blaster) and let it soak for a while.
Then spray it again and immediately turn the squirrel cage by hand and see how well it turns. If it's not smooth, it needs to soak some more and the bearings may be shot. Then you'd have to replace the bearings or the motor.
It is turns smoothly, you need to unplug the power cord and inspect the area where the cord plugs into the motor. Look for charred connections. In some cases (as I did to mine a few years ago) you can clean up and/or bypass the connections, making sure they are clean and tight.
If the connections are bad and cannot be repaired, the motor will have to be replaced.
I bought a spare from an independent heating and cooling guy. Saw his truck, looked him up and called him. He sold me a good used one for $20.
Here's a helpful tutorial on how to replace such a motor. Lotsa pictures.
Some good videos about it here.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
12/18/2008 8:13:48 AM • LG Microwave • Answered on Dec 18, 2008
4answers
Burning wire smell
Since it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
11/22/2008 5:38:34 PM • LG Microwave • Answered on Nov 22, 2008
My new LG solardome MA3884vc overheats melamine plate @30 seconds
If your LG Solardome microwave oven is overheating a melamine plate within 30 seconds, there could be a few potential issues at play:
  1. Power Settings: Check to see if the power settings on your microwave are too high. If it's set to a high power level, it can cause certain materials, like melamine, to overheat quickly. Try reducing the power level and see if that helps.
  2. Plate Material: Melamine plates are not suitable for use in microwave ovens as they can overheat and potentially release harmful chemicals into your food. It's recommended to use microwave-safe dishes made of glass, ceramic, or microwave-safe plastic.
  3. Microwave Performance: If the microwave is consistently overheating items within such a short time frame, it might indicate a malfunction. In this case, it's best to contact LG customer support or a certified technician to inspect and repair the microwave.
  4. Placement and Usage: Ensure that the plate is placed centrally on the turntable and not touching the sides of the microwave. Also, avoid using the microwave for extended periods without interruption, as this can cause overheating.
  5. Testing with Different Materials: Try using a microwave-safe ceramic or glass plate to see if the issue persists. If other materials heat up quickly as well, it could indicate a problem with the microwave itself.
3/8/2024 3:08:42 PM • LG Microwave... • Answered on Mar 08, 2024
I have an lg convection microwave oven. Can I use foil while using convection roasting?
I have a new Kitchen Aid Convection Microwave with air fryer. I've not yet used the air fryer, but today I put a pan with a roast and set to convection roast and turned it on. I put the aluminum foil over the top of the pan and it sparked. I don't know why this happened. I'd sure like someone to let me know.
1/28/2024 12:31:51 AM • LG Microwave... • Answered on Jan 28, 2024
My LG microwave says PM in the morning. How do I change it to AM. THE MANUAL DOES NOT address this. Model LMV1683ST
Push clock button and press the Up/down buttons to change time to pm.
11/5/2023 2:52:13 PM • LG Microwave... • Answered on Nov 05, 2023
On the roof of my lg solardom microwave there is a hole in brown plate and arching. Can it be fixed?
Remove the contaminated and fit a new Waveguide cover.
3/23/2023 8:08:01 AM • LG Microwave... • Answered on Mar 23, 2023
How to remove door COVER from door of LG Microwave model LMHM2017ST
Here are the steps to remove the door cover from the door of your LG Microwave model LMHM2017ST:
  1. Unplug the microwave from the power source.
  2. Open the microwave door and locate the four screws on the inner edge of the door.
  3. Use a Phillips screwdriver to remove the four screws.
  4. Carefully separate the outer door panel from the inner door panel.
  5. You will now see the door cover attached to the outer door panel.
  6. Use a flathead screwdriver or plastic pry tool to gently pry the door cover off of the outer door panel. Start at one corner and work your way around the edge.
  7. Once the door cover is removed, you can replace it with the brushed silver cover from the new door.
  8. To reassemble the door, simply snap the new cover onto the outer door panel and then reattach the outer door panel to the inner door panel using the four screws you removed earlier.
Make sure to be careful when removing the door cover, as it can be fragile and may break if handled roughly.
2/26/2023 5:09:19 PM • LG Microwave... • Answered on Feb 26, 2023
LG LMV1773SS microwave. Where are the fuses located on it please?
Question edited for clarity. It depends where you live? In the UK, the fuse is in the wall plug. In the US and other countries it _may_ be at the rear where the mains lead goes in. Sometimes they pull out, sometimes there is a small screw cap. If you are thinking of getting inside it, this Tip I wrote applies. https://www.fixya.com/support/r29874712-repairing_microwave_ovens ..
11/19/2022 1:37:48 AM • LG Microwave... • Answered on Nov 19, 2022
LG Microwave Logo
26 questions posted
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
LG Microwave Ovens
  • LG Microwave Ovens
Most Popular Question
burning wire smell
  • Microwave Ovens
