20 Most Recent
GE Profile Over-the-Range Microwave Questions & Answers
I need to replace the interior bulb on my GE
The oven interior bulb is on the top. Look closely at the grille above the door. There are two recessed screws that hold the grille in place. Remove these and carefully pull the grille straight out. You may have to wiggle it a bit - it's a tight fit on most of those I've serviced. Look in the center of the oven above the door. There is a sheet metal cover held in place with one or two screws (usually one, plus a plastic tab going into a slot in the sheet metal). Remove this screw and pull out the sheet metal. You will see the light bulb and the microwave stirring plate motor. Note that the instructions say you should unplug the oven before changing the light bulb. GE's lawyers are afraid you'll stick your fingers in the wrong place and somehow get shocked if you don't have the power removed.
How do i replace the inside light in a ge mirowave
The inside light is not meant to be user replaced, so you would have to remove the oven from the wall to do it.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
You can find helpful
exploded view diagrams and order parts (such as the bulbs) by entering your full model
number here. That's how you can find where the bulb is.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
I've got a GE Advantium 120/Model ZCS1001KSS01, the display will get lines thru it, and comes in and out of view, and will always finish its cycle. however, when you go back to use, it is dead.
The problem with your Display of your GE Microwave/Speedcooker is not the Digitron WB27X10856 display board? The flickering and ultimately failure over of the display is due to the WB27X10861 GE microwave control board which is a rebranded (LG 6871W1A417/6871W1A417A board) which GE then sells as a markup. The princple purpose of this board is to convert (i.e. rectify) AC to DC at various voltage levels needed by the rest of the microwave to run their control circuits in the microwave. A portion of the GE microwave is always on so the AC/DC supplly is always on. Overtime the electrolytic capacitors in a section of the board fail or degrade to a point they the DC suppy starts to produce ripples in the DC power supply which results in circuit board failures. These ripples produce deep spikes of voltage of 120 Hz that the other circuits are sensitive too. I just exmined a failed WB27X10861 board and measued the capacitance of each of the seven electroylic capacitors. Of the 7 capacitors, 2 had failed over time. The others 5 have degraded 10 to 15 percent but still within their design spec. The two that failed, C07 - 1000uF 25 V had a measured value of 207uF and the other C08 - 220uF had a measured value of 13uF. There was no visible bloating on either SAMWHA SG capacitor. Nomally, these capacitors are rated at 2000 hour at 85 degree C. 2000 hr is only 83 days, but since the voltage is less and the temperature is probably 40 to 50 degrees inside the capacitor these capacitors may last 10 years. They harder they work the shorter the lifespan. There are two solutions, either purchase a new replacement control board or replace the failed C07 and C08 capacitors within the failed board with better ones. You can easily buy 10,000 hour , 105 degree C rated capacitors for probably 25 cents more than 2,000 hour capacitor. Most people don't have the resouces to repair a board so buying a new board is their only solution. Don't buy a used board on ebay because a used board is probably on the verge of failure.
