20 Most Recent
Char-Broil CharBroil Master Flame Gas Barbecue Grill Questions & Answers
New Charbroil gas regulator leaks
The connector on the grill side that connects to tank may be bad. Call manufacturer and they should send you a new hose and regulator for free since it is a new grill. If grill does the same then replace tank.
I have a gas grill that has set for about two
I shut off the gas at the tank and grill. Removed the regulator from the tank and turned on the knobs on the grill for one minute. Then turned off the grill reconnected the gas line to the tank and opened the tank knob slowly.
Flame Shooting out the front
You clearly have a gas leak. Inspect the suspect area for loose connections like the gas delivery pipe to the burner assembly. Try to reconnect them. If there is a hole in it you can use some muffler repair adhesive but I would just get a new part. Often the company will send you free parts as a good gesture to assure encourage repeat business. Check out the links below. The second one offers free shipping.
www.charbroil.com/CharBroilWarranty
www.clagrills.com/grillparts/charbroil/charbroil-grill-parts-home.htm
Side burner lights but not main burner on gas grill
If you smell gas, don't attempt to light the burner. Instead, turn the gas off and inspect the fuel tank, lines and burners once the smell of has has cleared. Always grill where you have adequate ventilation and perform all repairs only after the grill has fully cooled from use.home lights
