20 Most Recent ASUS R1E-B1 Tablet PC Questions & Answers
3answers
Laptop is not playin any sound?, it just says no
I was also having such kind of problem with my asus laptop. I tried to replace the sound driver. but no better luck. so i've contacted to Asus tech support on toll free number- 1-800-585-2494 and Found the solution for my laptop. Get the best Asus Computer Support by Asus Support . hope they will help you to fix your problem related to asus.
4/5/2018 11:46:02 AM • ASUS R1E-B1... • Answered on Apr 05, 2018
ASUS F3S startup problems...
Have you tried doing a system recovery using the "hot" keys for the machine. Contact ASUS support for the instructions.
4/11/2017 9:25:36 PM • ASUS R1E-B1... • Answered on Apr 11, 2017
No power when plugged in? What did I do?
If you have a volt-ohm meter check that you have voltage at the plug to the computer. If no voltage, the power supply is bad or the socket does not have power (circuit breaker) change to a known working 120vac socket. Dobble check your laptop's power supply. If still bad, see if you can barrow one, or take laptop to repair shop and ask them to try their power supply. Then you will know to purchase a replacement.
3/31/2015 1:39:08 AM • ASUS R1E-B1... • Answered on Mar 31, 2015
My Asus tablet in Internet Explorer is locked with a message ; Attention Potentai l threat detected. I cannot remove this page or X out of it??
Download an app called Taskmanager. Run/open it and elect to end all running programs. This should close your web browser. Im guessing when you say internet explorer you mean Safari?
2/6/2015 7:02:26 PM • ASUS R1E-B1... • Answered on Feb 06, 2015
0answers
I have a new transformer 16 gb tablet.
http://www.asus.com/Eee/Eee_Pad/Eee_Pad_Transformer_TF101/#download
Just search at the bottom of this site and select Android from the OS list and you will find different language versions to download in PDF format here.
9/9/2011 1:51:25 PM • ASUS R1E-B1... • Answered on Sep 09, 2011
My laptop screen is flipped
No reset is necessary to fix this problem. Screen rotation is a typical feature on many laptops.
To rotate the display on the screen 180 degrees, simply press CTRL, ALT & down arrow on your laptop's keyboard.
6/14/2011 7:40:57 PM • ASUS R1E-B1... • Answered on Jun 14, 2011
How can i move my
on the mouse pad sometimes you will find a little touch button that immobilses the pad
8/3/2010 9:39:44 PM • ASUS R1E-B1... • Answered on Aug 03, 2010
I need to put the laptop on a monitor but screen
Usually FN and F5..............Try FN with other F? keys if it doesn't work with F5
7/15/2010 11:47:24 PM • ASUS R1E-B1... • Answered on Jul 15, 2010
Hi I have an ASUS Eee PC notebook I am a techno
Uninstall the wireless adapter under the device manager, restart the computer.
Let me know if that solves your issue.
4/5/2010 4:35:16 AM • ASUS R1E-B1... • Answered on Apr 05, 2010
My screen has flipped 90 degrees. how do i get it
Use CTRL +ALT+ (Arrow keys)to rotate the screen.
1/13/2010 7:01:42 PM • ASUS R1E-B1... • Answered on Jan 13, 2010
THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
12/31/2009 8:26:17 AM • ASUS R1E-B1... • Answered on Dec 31, 2009
How can i run xbox360 through HDMI through laptop
unfortunatley you cannot use your laptop as a tv for a video gaming system im sorry!
12/22/2009 6:45:00 AM • ASUS R1E-B1... • Answered on Dec 22, 2009
How do I load M2 memory card into asus X71Q
hi frnd.. try getting a usb memory card reader tat will help u... Take care...
9/21/2009 4:41:30 PM • ASUS R1E-B1... • Answered on Sep 21, 2009
2answers
Unable to move the cursor
check for a virus
7/20/2009 7:37:50 PM • ASUS R1E-B1... • Answered on Jul 20, 2009
Desktop PCs Cursor is stuck in the middle of the screes
Close open apps - could be something else hanging up everything (try keyboard; alt+F4, etc) if no luck try reboot, make sure is plugged in before power up
4/5/2009 3:40:12 AM • ASUS R1E-B1... • Answered on Apr 05, 2009
Asus F3S Laptop Graphics Card Died
If you have run the laptop in safe mode it uses the standard VGA graphics driver, and this indicates the onboard graphics card is still functioning.
Try connecting and external monitor to your laptop and the boot up your laptop.
Then :-
1. Download the latest graphics driver from ASUS WEB site.
2. uninstall the graphics driver.
3. Reboot the laptop and install the new graphics driver.
4. Shut down and remove the external monitor and reboot.
5. Goto the Control panel - Display and check/set the settings for screen resolution, Colour setting etc.
11/14/2008 10:52:08 PM • ASUS R1E-B1... • Answered on Nov 14, 2008
No power
It will only heat up if power is being used, but it could also mean that the adapter is bad.
check with a multi tester inside for red and outside for black, check to see if you are getting at least 15 volts or higher voltage.
make sure you set the multitester to VDC, Thats Direct Current Voltage or DC voltage.
if you are getting power thru the adpater head try wiggling the tip a bit to see if theres a broken wire inside the head Adapter head tends to break at the tip sometimes.
if your getting power then you might have a broken adapter plug in the laptop, you might a suitable adapter plug at a electronic store or ebay, might need or reqiure some soldering on the board if you dont know how to solder i suggest you leave it to the PRO's.
if no power coming from the adapter then time to replace the adapter, i figure adapter last about 1-2 years before they need replacing due to wear and tear and neglect. If you do not take care of your electronics they will not take care of you!.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
7/28/2008 1:47:43 PM • ASUS R1E-B1... • Answered on Jul 28, 2008
ASUS R1E-B1 Tablet PC Logo
32 questions posted
Top ASUS Tablets & eReaders Experts
k24674
john h
Ngoro
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Tablets & eReaders
Most Popular Question
screen flipped 90 degrees get
  • Tablets & eReaders
