20 Most Recent
AT&T 8925 Tilt Smartphone Questions & Answers
My phone is lock help me plz
Do you want to unlock your HTC T8925 from AT&T network?If it yes,visit the site
Prounlocking.com here they are providing the unlock code with easy step by step unlocking instructions and unlock it.
My HTC tilt is givin
There is a possibility that your sim card has gone bad. If you have access to another AT&T phone (or whatever GSM provider you use) try it in that phone and see if it works. If it doesn't work the sim is bad. If it works you may want to try hard resetting your phone. To do a hard reset:
- Power the Device Off.
- Press and hold the left SOFT KEY and the right SOFT KEY, and at the
same time, use the stylus to press the RESET button at the bottom of
your device.
- Release the stylus, but continue pressing the two SOFT KEY'S until you see the following message on the screen:
- "This operation will delete all your personal data, and reset all
settings to the manufacturer default settings. Press SEND to restore
manufacturer defaults, or press any other button to cancel."
- Release the two SOFT KEY'S, and then press SEND CALL the button on your device.
Before doing a hard reset, back up any information from the phone that you want to keep as all user data/programs will be lost and the phone will be put back to factory settings.
Hope this helps. Let me know if you have any questions.
Ray
Need to unlock an old
Since your phone is locked, it means you need to unlock the phone to be able to use it again. It is certain that you cannot unlock this phone for free, anywhere or on any site.
Though there are some phones that can be unlock for free, but unfortunately, yours cannot be unlocked for free because it's model phone.
Some sites offer to unlock phones and charge some amount of money, but I won't recommend that for you because those unlock codes are not reliable.
I would advice that you take the phone to a phone tech within your area/vicinity, and your phone will be unlocked there within a couple of minutes. The phone code will be reset with with computer using a phone cable. I'm sure you do not have the facilities to unlock your phone that's why I'm referring you to a phone tech.
But if you want to unlock your phone online, you can visit this link:http://mobileunlocked.com/index.php or http://www.unlockadvantage.com/index.php or http://www.mobile-unlocker.com/
In summary, there are two was methods by which you can unlock the phone. 1. it's either you take it to a phone repair shop and get it unlocked or 2. visit any of the above links, and follow instructions to unlock.
So you can either take the phone to a repairman within your area/vicinity or try any other the above links.
Good luck.
I dear,I have a problem
You
can
get the unlock code by contacting your current service provider
customer care department.If your phone is locked you can use any of
your friends phone to make this call. The
service
provider will then provide you the unlocking codes.
Remember
that the reason why the codes are provided only through customer service
provider is they will make a check on your name and identity proof at
the time of your call. If the information is found to be correct and
matching with their data then you will be provided with the codes.
Everything is done for free of cost and you are not going to be charged
for this process.This
is
the universal solution and is useful for many customers who are
facing these kind of problems. Don't believe in any websites which
provides unlock codes. All are fake. Only your service provider can
provide these codes.
Another alternative is, you can take the
phone to any authorize phone service center to help unlock the phone,
because to unlock your phone, you will need some kind of software, USB
cable
etc to unlock the phone, so you can also go a nearby phone service
center to unlock the phone,
but calling your network service provider is the best because they have
the records of your phone and can easily help to unlock it.
Take
care.
UNLOCK
i dont think its going to ask for code, you just have to enter it! Where did you get your code from? I've been trying to get one
I want unlock my cellphone
samsung
Visit www.FreeYourCellphone.com
they can unlock any pone from Fido, Rogers, AT&T, T-Mobile, Verizon, Bell, Telus, Sprint, Wind Mobile and Virgin Mobile(Canada) and more
They are major suppliers for most resellers so there price is good and service is super fast and professional
They can definitely unlock your Samsung
http://www.FreeYourCellphone.com
Cheers!
Use titl htc as a modem?
If you want to tether your phone's data plan to your computer, go to 'Start > Programs > Internet Sharing'. You will be allowed to connect to your PC through either USB or bluetooth PAN.
Hope it works for you.
Regards,
Carlos
I bought my htc tilt 2 used and did not come with
It comes with Vista and Windows 7 its called Windows Mobile Device Center and Sync Center on 7. On XP you just download Active Sync and install it.
http://www.microsoft.com/ireland/windowsmobile/activesync/default.mspx
HTC Tilt (Trouble Reading SIM Card)
I posted a little too early. There was one other trick I've used and I guess I should have started with that. The problem is indeed related to the SIM not getting enough downward pressure on the contacts to be recognized.
So I took a small strip of paper, about 3/8" by 1 1/4". I folded it three times. When you fold it one end will be closed and the other end will have the two edges of the paper that can open up. Using the open end will make it harder to slide under the bracket. So you will want to take the closed end and gently side it above the SIM card underneath the silver metal bracket that holds the SIM in place.
I used a post-it note as the paper but anything will do. It was working with just a double thickness but I wanted to be sure so I moved up to three layers. Depending on the tolerances of your phone you might be able to only do double layer and still be able to slide it in. Or you might need to go to four layers.
I hope this solves it for you.
/text for Google's indexes so others can find this: HTC Kaiser 8925, Cingular 8925, AT&T Tilt 8925, SIM Card is missing,
My ATT Tilt seems to automatically drop calls
Possible reasons for call drop
1. If the
network is congested and if you are low priority user then your call might be
dropped.
2. The signal level for an ideal call is
Transmit +43db
Receive -60 ~ -80db
Some
times while receiving call, suppose due to path loss or shadowing, if you are
receiving signal level is -95db, then your call will be dropped.
3. If the Antenna in the Phone might be at fault.
In other Words, give a Call to Service Provider and tell them to Refresh the Network. If Problem still remains unsolved, either the Service Provider have changed their Frequency which is affecting your Cellphone or the Antenna is at Fault and not able to Continue Signals at the same speed.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
