20 Most Recent
AT&T 6850G Router (ALL07735) Questions & Answers
I have an ATT modem/router
Welcome to Fixya. First can you please check if the wireless switch of your laptop is on? Can you please also check if your laptop can detect the wireless router? You can click on Start then Connect to and look for your Network Name or the name of the network, usually the name is 2wireXXX. Please provide me the information needed so that we can fix the issue.
Thanks
What is a WEP number
WEP stands for wireless encryption protocol it is used for used for security on wireless routers.
it is used to protect unwanted access to wireless networks.
Hope this solution has been helpful?
I forgot my user name
In case you have forgotten the password of your router, there is no way to recover it back.
ALL YOU CAN DO IS TO RESET THE ROUTER TO FACTORY SETTINGS
You may reset router to factory settings by pressing the reset button on the
back side of the router. Press the button for a few
seconds, the lights on the front would blink and the router would
restart with factory settings. Please note that ALL SETTING WOULD BE
LOST...AND YOU WOULD HAVE TO MAKE ALL NETWORK CONFIGURATIONS AND SETTINGS ALL OVER AGAIN
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
12/21/2010 11:21:59 AM •
AT&T 6850G...
Answered
on Dec 21, 2010
Need default credentials for AT&T
if it is a 2wire
look on the bottom there wil be three rows of numbers
xxxxxxxxxxxx
>xxxxxxxxxxx xxxxxxxxxxxx
the middle row should be 10 digits this is the passkey
to access the internet through at&t dsl login is your email address with att/sbc pw is the one for that acount.
11/18/2010 12:44:29 AM •
AT&T 6850G...
Answered
on Nov 18, 2010
Need router password recovery
Go to the router configuration page with the I.P. address 192.168.1.1 The default user name is admin, leave the password field blank.
Green wireless light is not
Can you please check the Power to the wireless Router.
Check the Power adapter , it might have a loose connection.
If the wireless router is not getting Power then you might have a bad power adapter.
I lost the paper with
There is a Reset pin on the Wifi, press the button once and connect the wifi to ur computer using LAN cable, once it is connected it will prompt for a New password.
Revert back for any queries
Router stopped working after futsed
Do a manual reset. Find the reset button. Hold it down for 30 seconds. then unplug the power while still holding the reset button down. count another 30 seconds then plug it in and count another 30 seconds, all while holding the reset button down.
This should for sure reset the unit. You should now be able to log in under all the defaults and try configuring it again.
Wireless not working
If you can detect the wireless network but you cannot connect to it, check the following:
1. Be sure that you are typing the correct network key (WEP, WPA-PSK).
2. If the wireless is unsecured, but still you can't connect to it, try to change the wireless channel.
3. Try to power cycle the router (disconnect the power cord from the wall socket for 5 minutes, then plug it back in).
4. Reboot the computer and try to turn off / on the WiFi of your laptop.
5. Reconfigure the router's wireless settings.
6. If same problem occur, contact the manufacturer and have them upgrade the firmware of your router.
If you cannot detect the wireless network, try the following:
1. Power cycle the router for 5 minutes.
2. Reboot the computer and try to turn off / on the WiFi of your laptop.
3. Change the angle of the router's antenna.
4. Change the wireless channel.
6. Upgrade the firmware of your router.
If nothing happens, then the router could be defective. Contact the manufacturer for RMA.
I have a new HP
You will need to check the wireless settings of
the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
How do I set up the security on my AT&T
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Lost wep key for router
Hold down the reset button for 30 seconds to restore the default settings, it removes all security and the wep key.
Sim mep locked
page 58
reset it yet.?
https://www.att.com/support_static_files/manuals/ATT_Mobile_Hotspot_Elevate_4G.pdf
SBCGL0baL CuStOMeR SuPPoRt $[+1-855.536.5666] $$O#O ''+ CUSTOMER SUPPORT
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 5000 or more spams per day, and it's not keeping up with the flood. Please help us out.
