20 Most Recent Ohm DAYTON 12" QUATRO SERIES SUBWOOFER 4 Car Speaker Questions & Answers
Can I replace the woofers in vs-150's with a pair of 15" cerwin-vega 158's
If they are the same physical size, yes. However, you will have reduced volume due to the higher impedance and possibly a mismatch if using a passive crossover.
6/16/2022 6:29:35 AM • Ohm Car Audio &... • Answered on Jun 16, 2022
CAN MY BERRINGER ULTRA BASS BXL 3000A HANDLE A 4 OHM SPEAKER
I doubt it as the driver is designed specifically for the amplifier. Pity it is under powered.
4/4/2022 7:05:36 AM • Ohm Car Audio &... • Answered on Apr 04, 2022
Crest Audio CPX 1500 help.
Read the manual! The Bridge mode on stereo amplifiers is often misunderstood relating to actual operation and usage. In basic terms, when a 2-channel amplifier is operated in the Bridge mode, it is converted into a single-channel unit with a power rating equal to the sum of the power rating for each channel, at a load of twice that of the single- channel rating. For example, the CPX 1500 is rated at 750 watts RMS per channel into 2 ohms. The Bridge rating is 1500 watts RMS into 4 ohms (minimum load). Bridge mode operation is accomplished by placing the MODE switch in the BRIDGE position, using only the BRIDGE Speakon connector or the red binding posts for the output, and using the CHANNEL A input. All CHANNEL B input func-tions are defeated and serve no purpose now. Bridge mode operation can be used to drive sound distribution systems in very large public address applications. Another common use for the Bridge mode is in subwoofer applications where very high power levels are required to reproduce extremely low frequencies with ade- quate headroom. Such enclosures usually contain 2 or 4 loudspeakers to handle the power levels involved. For Bridge mode usage, the enclosure impedance must be 4 or 8 ohms. Never below 4 ohms.
10/25/2021 4:21:17 PM • Ohm Car Audio &... • Answered on Oct 25, 2021
Can a behringer nx6000 play at a 2 ohm load
yes it can https://www.sweetwater.com/store/detail/NX6000--behringer-nx6000-power-amplifier
10/20/2021 4:28:45 AM • Ohm Car Audio &... • Answered on Oct 20, 2021
I have an SPL z2x-820 amplifier, I want to bridge the two channels into one.y question is does it matter what kind of sub I get or as long as it handles the correct 2 ohm load and wattage I should be fine?
It is ok to bridge the two input channels - that is known as mono or monaural, but it isn't a good idea to bridge the outputs without knowing the type of output stages. You could try it but don't be surprised if it doesn't work longterm, certainly you must observe the polarity. If it is your intention to use it as an amplifier to drive a subwoofer you will probably be disappointed by the performance due to the amplifier being built to deal with a wide spectrum of frequencies rather than being designed to amplify mostly subaural frequencies - certainly some filtering will be needed to block unwanted frequencies from the amplifier input. Because the amplifier has the theoretic capability to pump out 230 watts per channel into a 2 ohm load, there is no necessity to provide a 2 ohm load, in fact it was probably designed as such so it could use 2 x 4 ohm speakers in parallel for each channel providing good power handling on a budget.
12/19/2020 7:04:52 PM • Ohm Car Audio &... • Answered on Dec 19, 2020
If I buy a pair of Yamaha CBR15 speakers , and I configure them as a 4 ohm load, how many watts is appropriate to drive that load?
Hi John, this CBR15 speaker model, is specified for real power handling 500 watts each speaker If you connect the two Yamaha CBR15 in parallel, you will get an impedance of 4 ohms and an effective power handling capacity of 1000 watts, in this way you can apply that power, without risk of damage I hope you serve my comment Regards Franco Dosil Hola John, este modelo de bafle CBR15, esta especificado para manejo de potencia real 500 watts cada bafle Si conectas los dos Yamaha CBR15 en paralelo, obtendras una impedancia de 4 ohms y una capacidad de manejo de potencia efectiva de 1000 watts, de esta manera puedes aplicar esa potencia, sin riesgo de da?o Espero te sirva mi comentario Saludos Franco Dosil https://mx.yamaha.com/files/download/other_assets/8/332498/cbr15_es_om_a0.pdf https://mx.yamaha.com/es/products/proaudio/speakers/cbr/index.html
8/21/2019 4:52:15 PM • Ohm Car Audio &... • Answered on Aug 21, 2019
Can I put a t1 10 that's 4 ohm and 1 t1 that's 2 ohm together on a jl 500/2
dear sir, impedance matching between the amplifier and the speakers is very important. the total impedance will be 8 divided by 6=1.6666666 ohms , this impedance is not healthy for any amplifier, because the impedance must be between 4 ohms and 16 ohms
9/18/2018 8:08:44 PM • Ohm Car Audio &... • Answered on Sep 18, 2018
I have 2 2 ohm speakers what ohm amp do I need to run themThey are kickers
An amp that will handle 2 ohm stable as long as they are hooked up left and right. Try a fosgate or kicker amp. Just look up specs on the model you want.
12/7/2016 4:35:35 AM • Ohm Car Audio &... • Answered on Dec 07, 2016
Have a avionixx cxd 2800 amp an 2 15 inch solar basics want to wire 1 ohm stable, how can I do it
Usually the amplifier is stable at 1 ohm or it is not. Usually not something you can change. If you are asking how to wire the speakers at 1 ohm that's a different question, but first you have to make sure your amp is 1 ohm stable of course.
6/25/2016 2:25:21 PM • Ohm Car Audio &... • Answered on Jun 25, 2016
I have 1ohm speaker can I wire it to 2 ohm or is it the same way
Can you explain with a little more detail like does it have dual coils or single?
4/13/2016 3:08:32 PM • Ohm Car Audio &... • Answered on Apr 13, 2016
I have 3 4 ohm dvc subwoofers and a 4500 watt power acoustic class d amp can i use 0.67 load and be ok
If your amp is the GT1-4500D, then no. The amp is only stable down to 1 ohm. Operation below 1 ohm load is not guaranteed.
11/4/2015 6:18:27 AM • Ohm Car Audio &... • Answered on Nov 04, 2015
How do I hook up my interfire ib2900c amp correctly??...hooked up 2 dvc 2 ohm 12" subs ...to 2ohm stereo load..but all I get is loud blurring out sound forcing me to off..what do I do??
If the subs you have are 2 ohm DVCs, that usually means each voice coil is 2 ohms. Putting the DVCs in parallel will make the sub 1 ohm, which is beyond the capability of the amp (which is only stable down to 2 ohms per channel). Putting each subs DVCs in series (for a total of 4 ohms per channel) will at least allow the amp to operate properly, even though you will not be able to maximize the output power. http://www.interfireaudio.com/download/interfire_catalog_2009.pdf
11/4/2015 5:44:30 AM • Ohm Car Audio &... • Answered on Nov 04, 2015
2 dvcoil 4ohm.subs, need 2 ohm load total for monoblok.amp. how do I wire.it
If you run one sub with the DVCs in parallel, you would get 2 ohms. If you run both subs with all DVCs in parallel, you would get 1 ohm. If you run both subs with DVCs in parallel and subs in series, you would get 4 ohms. If you run both subs with DVCs in series and subs in parallel, you would get 4 ohms. If you run one sub DVCs in series and the other sub DVCs in parallel and both subs in parallel, you would get 1.6 ohms but the subs would not be balanced. If you run both subs on only one coil and the subs in parallel, you would get 2 ohms (but only if the individual coils are rated for the full power)
10/28/2015 10:01:27 PM • Ohm Car Audio &... • Answered on Oct 28, 2015
How do I wire up a 12 inch 4 ohm DVC sub & what kind of amp should I be using?
800whatt amp 8ohm connect on first two
6/5/2015 6:37:18 PM • Ohm Car Audio &... • Answered on Jun 05, 2015
Ohm DAYTON 12" QUATRO SERIES SUBWOOFER 4 Car Speaker Logo
1 questions posted
Top Ohm Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you an Ohm Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Ohm Car Audio & Video
Most Popular Question
berringer ultra bass bxl 3000a handle 4
  • Car Audio & Video
