remove the rca wires and the speaker output wires and just leave the 12volt power/ remote/ and ground connected. turn on the radio and see if the light goes off. if it does then one of your speaker or rca wires are shorted, plug in one at a time and see which one gets you the red protect light, then find the short for that speaker/rca wire. if the red light turns on with only the 12volts/remote/ground, then the short is in the amp.
If they are the same physical size, yes. However, you will have reduced volume due to the higher impedance and possibly a mismatch if using a passive crossover.
Read the manual!
The Bridge mode on stereo amplifiers is often misunderstood relating to actual operation and usage. In basic terms, when a 2-channel amplifier is operated in the Bridge mode, it is converted into a single-channel unit with a power rating equal to the sum of the power rating for each channel, at a load of twice that of the single- channel rating. For example, the CPX 1500 is rated at 750 watts RMS per channel into 2 ohms. The Bridge rating is 1500 watts RMS into 4 ohms (minimum load). Bridge mode operation is accomplished by placing the MODE switch in the BRIDGE position, using only the BRIDGE Speakon connector or the red binding posts for the output, and using the CHANNEL A input. All CHANNEL B input func-tions are defeated and serve no purpose now. Bridge mode operation can be used to drive sound distribution systems in very large public address applications. Another common use for the Bridge mode is in subwoofer applications where very high power levels are required to reproduce extremely low frequencies with ade- quate headroom. Such enclosures usually contain 2 or 4 loudspeakers to handle the power levels involved. For Bridge mode usage, the enclosure impedance must be 4 or 8 ohms. Never below 4 ohms.
It is ok to bridge the two input channels - that is known as mono or monaural, but it isn't a good idea to bridge the outputs without knowing the type of output stages. You could try it but don't be surprised if it doesn't work longterm, certainly you must observe the polarity.
If it is your intention to use it as an amplifier to drive a subwoofer you will probably be disappointed by the performance due to the amplifier being built to deal with a wide spectrum of frequencies rather than being designed to amplify mostly subaural frequencies - certainly some filtering will be needed to block unwanted frequencies from the amplifier input.
Because the amplifier has the theoretic capability to pump out 230 watts per channel into a 2 ohm load, there is no necessity to provide a 2 ohm load, in fact it was probably designed as such so it could use 2 x 4 ohm speakers in parallel for each channel providing good power handling on a budget.
Hi John, this CBR15 speaker model, is specified for real power handling 500 watts each speaker
If you connect the two Yamaha CBR15 in parallel, you will get an impedance of 4 ohms and an effective power handling capacity of 1000 watts, in this way you can apply that power, without risk of damage
I hope you serve my comment
Regards Franco Dosil
Hola John, este modelo de bafle CBR15, esta especificado para manejo de potencia real 500 watts cada bafle
Si conectas los dos Yamaha CBR15 en paralelo, obtendras una impedancia de 4 ohms y una capacidad de manejo de potencia efectiva de 1000 watts, de esta manera puedes aplicar esa potencia, sin riesgo de da?o
Espero te sirva mi comentario
Saludos Franco Dosil
https://mx.yamaha.com/files/download/other_assets/8/332498/cbr15_es_om_a0.pdfhttps://mx.yamaha.com/es/products/proaudio/speakers/cbr/index.html
dear sir, impedance matching between the amplifier and the speakers is very important. the total impedance will be 8 divided by 6=1.6666666 ohms , this impedance is not healthy for any amplifier, because the impedance must be between 4 ohms and 16 ohms
An amp that will handle 2 ohm stable as long as they are hooked up left and right. Try a fosgate or kicker amp. Just look up specs on the model you want.
Usually the amplifier is stable at 1 ohm or it is not. Usually not something you can change. If you are asking how to wire the speakers at 1 ohm that's a different question, but first you have to make sure your amp is 1 ohm stable of course.
If the subs you have are 2 ohm DVCs, that usually means each voice coil is 2 ohms. Putting the DVCs in parallel will make the sub 1 ohm, which is beyond the capability of the amp (which is only stable down to 2 ohms per channel). Putting each subs DVCs in series (for a total of 4 ohms per channel) will at least allow the amp to operate properly, even though you will not be able to maximize the output power.
http://www.interfireaudio.com/download/interfire_catalog_2009.pdf
If you run one sub with the DVCs in parallel, you would get 2 ohms. If you run both subs with all DVCs in parallel, you would get 1 ohm.
If you run both subs with DVCs in parallel and subs in series, you would get 4 ohms.
If you run both subs with DVCs in series and subs in parallel, you would get 4 ohms.
If you run one sub DVCs in series and the other sub DVCs in parallel and both subs in parallel, you would get 1.6 ohms but the subs would not be balanced.
If you run both subs on only one coil and the subs in parallel, you would get 2 ohms (but only if the individual coils are rated for the full power)
