20 Most Recent Insignia NS-PDVD8 Portable DVD Player Questions & Answers
5answers
Video and autio not in sync
Are the certain DVD's original store bought or burnt? Also, did you try a lens cleaner?
3/11/2020 8:49:58 AM • Insignia... • Answered on Mar 11, 2020
4answers
Unlock region codes
Hi All,
I am looking for the region unlock code for a Sony portable
DVD player.Model number DVP-FX720
3/11/2020 6:05:25 AM • Insignia... • Answered on Mar 11, 2020
0answers
3answers
Turning on
I second quavuama. I had the same symptoms after my four-year-old "broke" it. He actually figured it out and suggested the fix. He said "Daddy, the little button is stuck..." OK, yeah right, I said. But he pointed to the small auto shut-off button just above the source and setup buttons. When the lid closes the button is pushed down and off goes the picture. Well little four-year-old fingers was fingering the button and it got stuck in the down position. I used a sharp tip to work it back to the "sprung" position. Picture now comes on.
12/26/2013 7:27:27 AM • Insignia... • Answered on Dec 26, 2013
The digital labs k715 portable
how long have you been using this player and when did this begin?
Remove the disc and try another. If the player refuses to eject the disc, remove it from the wall and fix it back and fix it back again. Then turn the player on.
If the player still gets stuck on "loading" mode for other disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
9/9/2011 12:34:20 AM • Insignia... • Answered on Sep 09, 2011
Hello, I'm trying to unlock
If You enterd boot passward then you go service centre and open your pc.if you enterd window passward then you just pasward reset key or reinstal your window. . .
3/13/2011 5:54:43 AM • Insignia... • Answered on Mar 13, 2011
I have a digital labs
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
3/5/2011 8:12:23 PM • Insignia... • Answered on Mar 05, 2011
HI, I HAVE BOUGTH 2 INSIGNIA DVD PLAYERS FOR
Please unlock it here : www.dvddemystifiziert.de/codefree_en/sony.html
Kind Regards, Jay
2/21/2011 11:03:25 AM • Insignia... • Answered on Feb 21, 2011
The screen is constantly white
I have run into the situation when I took a brand new player apart and not all the cables were plugged in the board. Since yours is brand new it needs to go back to the store for exchange, if you take it apart the warranty will be void.
1/9/2011 10:43:54 PM • Insignia... • Answered on Jan 09, 2011
ITS PLUGED INTO AN AC WALL UNIT. TURN IT ON AND AN
hi,
if u are using an adapter( power supply) then it have some problem. just replace the power supply the problem will solve. now the the dvd is attempting to work on battery because it did't get power from its AC power supply.
ok
12/30/2010 3:57:41 AM • Insignia... • Answered on Dec 30, 2010
2answers
No picture and no sound but i can hear the motor
Check the sleep button/reset button, which sometimes gets stuck on this model. It is a small, black button near the source and setup buttons.
11/28/2010 8:59:23 PM • Insignia... • Answered on Nov 28, 2010
Hi, have an Sony DVP-730
It is not possible to change region code of this dvd player.
Sorry.
7/14/2010 1:59:57 PM • Insignia... • Answered on Jul 14, 2010
Insignia NS-PDVD8 Portable DVD Player Logo
Popular Tags
63 questions posted
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
no picture no sound but hear motor
  • Televison & Video
