20 Most Recent
Hoover U5780-900 Windtunnel Cyclonic Bagless UprightVacuum Questions & Answers
Why are the belts burning and the brush not turning?
Check the ends of your brush roll. Most have bearings on the end and if one of those is locked up and will not turn it will burn the belt. Sometimes hair will get in the bearing area and will contribute to the bearing locking up.
Belt issue
Check the switch to the brush bar it might not be in the right position it needs to be in to run or not run should be in a little slot that turns it on and off
The roll brush will not turn when on floor. Too
Turn the belt inside out. This problem stems from a design flaw in the mechanism that turns the hoover from bare floor to carpet. After taking it apart I realized that the spring that pushes the belt tight (to make roller spin) is not any where near strong enough to keep the brush rolling. My solution was to turn the belt inside out (there by essentially shortening the belt and allowing enough pressure to be applied to the roller to keep it spinning. Horrible design flaw. I am an engineer and find this pathetic. Hope this helps someone.
Need belt 38528- brush belt
belts will stretch when they slip. There no adjustments on beater-bars. The way to prevent this is to have a height adjustment to be high on high pile and low for low pile rugs.
I have a hoover cyclonic
Are you sure you have the correct belt? The proper belt is # 59156500. It is 5/16" wide and about 2 1/2" in diameter. This is not a common belt.
