20 Most Recent ASUS Google Nexus 7 Questions & Answers
How can I download flash player ?
Tap "Install" on the next screen to confirm. When Flash is installed, head into your phone's stock browser (again, Google Chrome won't support your newly-installed Flash apk). On Android 3.0 or later, go to Menu (three dots next to the address bar on some phones) > Settings > Advanced > Enable plug-ins.
9/20/2019 5:17:24 PM • ASUS Google... • Answered on Sep 20, 2019
How do I get past the wifi question page
hai, do the first time user must activate the wifi to recognize, update a lot their systems and create your profile, not by the network wee usually use. so go find hot spot or borrow some one wifi connection for. After the process done, you can use network connection and data traffic like usual. hope its help
12/1/2015 7:39:08 AM • ASUS Google... • Answered on Dec 01, 2015
How to hard reset asus tablets
3/9/2015 3:30:54 AM • ASUS Google... • Answered on Mar 09, 2015
Indicator light on charger is not working but is charging my device. is this safe? or do I need to purchase a new charger head.
The light not working suggests a cheap horrible charger. Is this the one that came with the nexus? LED's usually outlive people, so the circuit may be of poor quality. I would change it just to be safe. Make sure you only charge it when you are there. Kind Regards, Dan.
9/8/2014 8:27:58 AM • ASUS Google... • Answered on Sep 08, 2014
It won't turn on
Let's try to hard reset your device, not sure if this will work on both models (2012 and 2013). What you are going to read next is a C/P, best of luck.
Hard Reset or Wipe via Menu
If your device is completely unresponsive, you still have one additional option. 1. Press the power button and both volume keys for several seconds. The computer screen will eventually blink off. Continue to hold until you see the Android recovery logo and the large Start selection at the top of the screen. If you are forced or desire to factory reset and wipe the device, select Recovery Mode. Your device will reboot. This reboot will be much slower than normal. 2. When you see the Android with red triangle, hold the power button down and press the volume up key until the wipe data/factory reset option appears. Press the power button to select it. Remember that this will erase all the data on your device. 3. With the volume keys select Yes - erase all user data and again press the power button to select this option.
3/12/2014 6:58:09 PM • ASUS Google... • Answered on Mar 12, 2014
Cant get any apps
Hi Kim, Inconvenience regretted, it may happen when the Framework services are blocking the Market. Here is what you need to do: 1. Click on Menu button> Settings 2. Select Apps 3. On Top right hand side, you will see "Downloaded", scroll left to see "ALL" 4. Under "ALL" , select "Google Services Framework" and click "Clear Data". Now try to access "Play Store" and download Apps. Thanks!
1/30/2014 5:34:19 PM • ASUS Google... • Answered on Jan 30, 2014
0answers
I can not connent my nexus 7 to inter net
If you're still carrying this problem with you and haven't found an answer to this. You can always set your device back to factory settings and start all over. Notice: You should back-up your data first!
12/18/2013 4:08:00 PM • ASUS Google... • Answered on Dec 18, 2013
Google support
Is this after serveral power-off and power-on attempts? If so, you may need to reset it to factory defaults by entering "recovery mode". Google "nexus 7 recovery mode" and follow the options within. All data on your nexus 7 will be lost.
12/6/2013 10:42:52 AM • ASUS Google... • Answered on Dec 06, 2013
Problems to download movies using Netflix
What sort of problems are you having? Connecting to the internet? Are you receiving any error messages? In order to troubleshoot your situation, we would need to gather more specifics to assist.
10/23/2013 9:39:59 PM • ASUS Google... • Answered on Oct 23, 2013
manual
Google Nexus 7 Manual
ASUS Google Nexus 7Uploaded on Jul 24, 2013
Tablet asus memo pad 10 me102a problem
you can buy another used from $15.00 on eBay.
10/23/2023 9:08:45 PM • ASUS Tablets &... • Answered on Oct 23, 2023
I wonder if it's possible to charge an Asus Nexus 0560 "tablet" through a charging plate?
"Some" of the 2013 Models will, Most tablets will not...You can buy an Insert that has a Magnetic tip on the end, The cord has another magnetic tip. Simple stick together. It all depends on the type of charger Male end that goes into that paticular Model....
5/3/2022 10:10:50 PM • ASUS Tablets &... • Answered on May 03, 2022
My asus tablet did ring when my phone rang but it now doesnt. Why
Check the "Do not disturb" mode on your phone. You need to switch it off.
8/24/2020 12:28:03 AM • ASUS Tablets &... • Answered on Aug 24, 2020
How do I detach the keyboard from screen of Asus tablet?
Detach the tablet to work and play anywhere, and dock to enjoy the comfortable keyboard, smart gesture-enabled touch pad https://www.upsers.review/
4/23/2020 5:05:53 PM • ASUS Tablets &... • Answered on Apr 23, 2020
Asus tablet Zenpad10: after factory reset Setup Wizard is crashing
Try holding the power button and the volume up button same time when hear a vibrate realise them both
2/17/2020 9:39:10 AM • ASUS Tablets &... • Answered on Feb 17, 2020
Asus tablet touch screenwill not allow me to move or scroll
Bonjour, Peut-?tre qu'il y a un probl?me au niveau de l'?cran,il vaudrait mieux aller chez un r?parateur pour ?tre s?r. https://www.distriphone.com/fr/2691-Pieces-detachees-Tablette-Asus
1/24/2020 10:36:57 AM • ASUS Tablets &... • Answered on Jan 24, 2020
Asus ZenPad tablet has developed a very low volume problem!
Bonjour, Le haut-parleur de votre tablette a peut-?tre subit quelques dommage.Vous pouvez voir cela avec un d?panneur: https://www.distriphone.com/fr/2691-Pieces-detachees-Tablette-Asus
1/24/2020 9:12:40 AM • ASUS Tablets &... • Answered on Jan 24, 2020
ASUS Google Nexus 7 Logo
42 questions posted
Top ASUS Tablets & eReaders Experts
k24674
john h
Ngoro
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Tablets & eReaders
Most Popular Question
google support
  • Tablets & eReaders
