20 Most Recent
Jenn-Air PRG3601P Gas Kitchen Range Questions & Answers
Prg3601p oven
I also have this problem Ihave replaced the igniter twice this helps some for a while I AM GETTNG READY to order my third one. had dealer replace once they had no answer cut lighting time from fifteen to twenty minutes to maybe five
9/14/2008 10:51:38 PM •
Jenn-Air...
Answered
on Sep 14, 2008
Jenn-air JGS9900 downdraft slide in gas range - no power and electrical outlet IS working
There are several possible reasons why your Jenn-air JGS9900 gas range may not have power:
- Tripped Circuit Breaker: Check the circuit breaker for the range in your home's electrical panel to see if it has tripped. If it has, reset it.
- Loose Electrical Connection: Check the power cord connection to the range to make sure it is secure. Also, check the wiring connections behind the range to ensure they are properly connected.
- Blown Fuse: If your range has a fuse, check to see if it has blown. You may need to replace it.
- Faulty Control Board: The control board is responsible for supplying power to the range's electronic components. If the control board is faulty, it may need to be replaced.
- Faulty Igniter: If the burners are not igniting, the igniter may be faulty and need to be replaced.
If none of these solutions work, it may be best to contact a professional technician to diagnose and fix the issue.
Jenn-Air jgs8860bdp broiler doesn't ignite.
There are a few potential issues that could cause the problems you're experiencing with your Jenn-Air broiler. Here are a few things you can try:
- Make sure the gas supply to the broiler is turned on and that there are no blockages in the gas line.
- Check the gas valve to make sure it is open and functioning properly.
- Make sure the gas burners are clean and free of any debris or obstruction.
- Check the broiler burner for proper ignition. It should ignite within a few seconds of turning on the broiler. If it does not, the burner orifice may be clogged and will need to be cleaned.
- Check the gas pressure to the broiler. If the gas pressure is too low, it can cause the flames to be low or go out.
- Make sure the broiler igniter is properly seated and connected.
Converting jenn-air dual fuel to propane
To convert the appliance pressure regulator from one gasto another, do either (1), (2) or (3) below: Your unit will beequipped with one of the three appliance pressureregulator types shown below.1. Remove the cap, push down and turncounter-clockwise. Turn the cap over and reinstall(figure 10).NOTE: The gas type you are converting to must bevisible on the top of the installed appliance pressureregulator cap.2. Remove plastic dust cover from cap nut on top ofappliance pressure regulator. Remove cap nut fromappliance pressure regulator (plastic dust cover comesoff with nut). "IMPORTANT" remove plastic dust coverfrom cap nut and reinstall on opposite side of cap nut.Reinstall cap nut to appliance pressure regulator andreplace dust cover. "CAUTION" be sure marking forthe type of gas to which appliance pressure regulatorhas just been converted is visible in top of cap nutbefore replacing plastic dust cover. (See figure 11).3. Remove cap and forcibly snap out plastic plunger frombottom of cap. Turn plunger over and forcibly snapback in original location (figure 12).NOTE: Plunger MUST snap into position; the gas typeyou are converting to must be visible on lower side ofplunge
We have a old Jenair
i would suggest having some one check out your your fuse box. they can wear out just like every thing else. the mounts fur the fuses get weak from heating up and cooling down. hope this helps.
I bought a Jen-air black
I would the color grout that matches the counter and yes it is heat resisitant. and it cleans up with a spung. be sure to all extra grout off before it drys
