20 Most Recent
Lynx LBQ27FRE (NG) Questions & Answers
What is so cool abat them
Having been in the grill business for a number of years, I can truly say, "There's not much that sets Lynx apart from any other high end stainless steel gas grill."
1. They use cast brass burners instead of cast stainless steel (no big difference in longevity there).
2. They use full ceramic briquets as a flame tamer As do several BBQ's Galore Gas Grills.
3 The grill is made entirely of 304 Stainless Steel, with some areas polished to a mirror finish. So does the Fire Magic grills.
4. They have as good a warranty as most of the other high end grills.
Is it a better grill overall, than those you'll find at your local home center? Definitely, Yes!
Is it worth over $2000.00? That depends on how much grilling and entertaining you do and how well you take care of the grill. All of them (High End or Low End) require routine cleaning and maintenance. Don't do it and you'll have problems. Also a good quality quilt lined cover is essential Not a $19.99 vinyl special.
Hope this helped answer you question.
There is only enough gas to lite one side and the
If this is a Propane gas Grill with a tank ... Turn the tank vale OFF. Disconnect the grill hose from the tank and wait 5 minutes before reconnecting it. After reconnecting the hose to the tank, turn the tank valve on VERY, VERY, SLOWLY (Slow motion, slow). Once the vale is completely open, light the burner farthest from the tank first and turn the burner to the highest setting. If the flame height appears normal repeat this procedure with the remaining burners. If the flame heights do not appear normal, turn the tank valve OFF and disconnect the hose. Remove the tank from the grill and lift it with one hand. Does it feel full or partially full? If not, and it's not a new tank, it may only have enough gas to barely light the burners. If the tank is full or partially full and the first procedure listed above didn't solve the problem, you need to replace the grill hose and regulator assembly. You can purchase one from just about any hardware or home improvement store that sells gas grills. Just take you old one with you for comparison. Remember, always turn the tank valve on VERY, VERY Slowly.
Happy Grilling!!
Hi, want to use
Push the knob in and hold it for 20 or 30 second then release should light if it does not it a bad thermo coupling
ON THE CAST IRON BURNERS THERE IS A PLATE WERE THE
This 'adjustable plate' is known as an 'air shutter' located at the tips of the venturri tubes which are the tubes that carry the propane from the valve to the burner. These air shutters allow you to control your flame by mixing oxygen with propane to create a yellow flame to a blue flame. The perfect flame is a uniform blue flame with a small yellow tip.
Unfortunately, these air shutters are considered part of the burner itself and cannot be individually replaced. However, if the burner and venturri tubes are separate from each other, you may be able to get a replacement venturri tube without having to replace the entire burner unit.
Hope this helps.
Ben
Tanks 2 You Propane
propanetanks2you.com
Grill will not light
Try replacing the regulator if you get no gas flow, or very weak gas flow. If you have gas flow and you are trying to light the grill with the ignitor. The rotary piezo ignitions must click with each turn, if they don't then they are bad and need to be replaced. If you have a new lynx with the glow plugs, check to see if they are glowing, if they are glowing and the grill has gas and still won't light, then the glow plugs are not getting hot enough which means you are leaking current somewhere and have to trace everything down to find the short.
Is "Halal" meat safe for humans?
Hi, Carole. According to the Wiki article on Halal, it is an Arabic word meaning "permissible," referring to food, objects or actions. With respect to food it is similar in intent to the Hebrew word, "Kosher." In both Islam and Judaism, for example, pork is not considered permissible. There is much more to know about Halal, but I'll defer to our Islamic neighbors to answer more fully. Short answer: entirely safe. Enjoy!
12/27/2023 4:43:31 AM •
Grilling
Answered
on Dec 27, 2023
How to take top grill off
You need to identify brand and model. Armed with that, someone may be able to assist you. Or, you can use google to search for a user manual if you include the brand and model in the search. What follows are general instructions for a lot of grills but may not fit your model:
Open the door(s) of the grill.
Look up at the bottom side of the grill.
Remove the grill screws going up into the bottom of the grill.
Tilt the grill forward at the top and release the springs from behind the grill.
Lift off the grill.
12/22/2023 4:51:21 PM •
Grilling
Answered
on Dec 22, 2023
I need Casio exilim v7 update 1.01 and 1.02
It is recommended to visit the official Casio website or contact Casio customer support for assistance with obtaining the firmware updates for your camera.
Typically, manufacturers make firmware updates available on their official websites under the support or downloads section. You can search for "Casio Exilim V7 firmware update" on a search engine to find the official Casio support page for your camera model. From there, you should be able to locate and download the firmware updates you need.
If you encounter any difficulties or are unable to find the firmware updates on the Casio website, I suggest reaching out to Casio customer support directly for further assistance. They will be able to provide you with the appropriate firmware updates and guide you through the process of updating your Casio Exilim V7 camera.
Please note that when performing firmware updates, it's essential to carefully follow the instructions provided by the manufacturer to avoid any potential issues or complications during the update process.
I hope this helps, and I wish you the best of luck in obtaining the firmware updates for your Casio Exilim V7 camera!
6/21/2023 2:43:05 AM •
Grilling
Answered
on Jun 21, 2023
