20 Most Recent
Lynx L30FR-1 Gas Grill Questions & Answers
Ignightor dont work and i put a new batt in it
Todd, the first thing to to do, is to remove the battery you just installed and look inside the battery holder for corrosion. If you see any, clean it off with a Q Tip sprayed with WD40. Then reinsert the battery with the Positive Tip (+) end facing you. If that didn't solve the problem, you'll need to trace down the wiring from the igniter module to each spark tip, at each burner. You want to see if all the wiring is intact and not damaged. Also, check the grounding wire from the igniter module to the grill's frame to see if it has come loose or has lost contact. If all this troubleshooting does not find a problem, it's a better than average chance that the Igniter Module will need to be replaced. You can purchase a new one from Lynx or find one online that will fit your make and model grill. Appliance Factory Parts online is a good place to find grill parts, even for discontinued models.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Rotisserie infra red value would
I'm assuming, that after you release the burner knob, the infrared burner goes out. You need to hold the knob in until the infrared burner gets glowing hot. If it doesn't remain lit after doing that, the thermocouple that keeps the burner lit, either needs cleaning due to a grease build up or replacing the thermocouple entirely. To clean it, alcohol and a cotton ball works well.
Hope this helps you troubleshoot and solve the problem.
ON THE CAST IRON BURNERS THERE IS A PLATE WERE THE
This 'adjustable plate' is known as an 'air shutter' located at the tips of the venturri tubes which are the tubes that carry the propane from the valve to the burner. These air shutters allow you to control your flame by mixing oxygen with propane to create a yellow flame to a blue flame. The perfect flame is a uniform blue flame with a small yellow tip.
Unfortunately, these air shutters are considered part of the burner itself and cannot be individually replaced. However, if the burner and venturri tubes are separate from each other, you may be able to get a replacement venturri tube without having to replace the entire burner unit.
Hope this helps.
Ben
Tanks 2 You Propane
propanetanks2you.com
Grill will not light
Try replacing the regulator if you get no gas flow, or very weak gas flow. If you have gas flow and you are trying to light the grill with the ignitor. The rotary piezo ignitions must click with each turn, if they don't then they are bad and need to be replaced. If you have a new lynx with the glow plugs, check to see if they are glowing, if they are glowing and the grill has gas and still won't light, then the glow plugs are not getting hot enough which means you are leaking current somewhere and have to trace everything down to find the short.
Is "Halal" meat safe for humans?
Hi, Carole. According to the Wiki article on Halal, it is an Arabic word meaning "permissible," referring to food, objects or actions. With respect to food it is similar in intent to the Hebrew word, "Kosher." In both Islam and Judaism, for example, pork is not considered permissible. There is much more to know about Halal, but I'll defer to our Islamic neighbors to answer more fully. Short answer: entirely safe. Enjoy!
12/27/2023 4:43:31 AM •
Grilling
Answered
on Dec 27, 2023
How to take top grill off
You need to identify brand and model. Armed with that, someone may be able to assist you. Or, you can use google to search for a user manual if you include the brand and model in the search. What follows are general instructions for a lot of grills but may not fit your model:
Open the door(s) of the grill.
Look up at the bottom side of the grill.
Remove the grill screws going up into the bottom of the grill.
Tilt the grill forward at the top and release the springs from behind the grill.
Lift off the grill.
12/22/2023 4:51:21 PM •
Grilling
Answered
on Dec 22, 2023
I need Casio exilim v7 update 1.01 and 1.02
It is recommended to visit the official Casio website or contact Casio customer support for assistance with obtaining the firmware updates for your camera.
Typically, manufacturers make firmware updates available on their official websites under the support or downloads section. You can search for "Casio Exilim V7 firmware update" on a search engine to find the official Casio support page for your camera model. From there, you should be able to locate and download the firmware updates you need.
If you encounter any difficulties or are unable to find the firmware updates on the Casio website, I suggest reaching out to Casio customer support directly for further assistance. They will be able to provide you with the appropriate firmware updates and guide you through the process of updating your Casio Exilim V7 camera.
Please note that when performing firmware updates, it's essential to carefully follow the instructions provided by the manufacturer to avoid any potential issues or complications during the update process.
I hope this helps, and I wish you the best of luck in obtaining the firmware updates for your Casio Exilim V7 camera!
6/21/2023 2:43:05 AM •
Grilling
Answered
on Jun 21, 2023
Propane not getting to burners; how do i fix
James,
Try Reseting the Regulator.....
1. Turn off the gas at the propane tank.
2. Disconnect the hose from the propane tank.
3. Open the lid of your BBQ Grill.
4. Turn all the burner valves to high.
5. Wait for 2 minutes.
6. Turn off all the burner valves.
7. Connect the gas line back up to the propane tank.
8. Turn on the propane tank slowly.
9. Light the grill using the proper ignition sequence.
Best to you.
6/5/2023 6:27:06 PM •
Grilling
Answered
on Jun 05, 2023
