20 Most Recent
Casio Mens PAG240-1CR Pathfinder Triple Sensor Multi-Function Sport Watch One Size Questions & Answers
Why isn't battery recharging in sunlight?
I own the a same CASIO PRG-240 watch.I think there is no problem.Charging every solar powered watch under direct sunlight has to be made in a well lighted and ventilated area, such as balcony and never behind a window glass.Charging from LOW to FULL is a long way (see instructions).Now showing FULL and when removed after a while, MEDIUM, is normal as the battery is not really fully charged.If you use an incandescent light,place the watch at least 50-60 cm distance from it.Usually there are no great results with the incandescent light.I never use this option.
Wear your watch for a couple of days (a week for example) under sunlight as much as possible and check.If it still shows MEDIUM after a time period, may be a battery replacement will solve the problem.
10/29/2018 11:48:44 AM •
Casio Mens...
Answered
on Oct 29, 2018
How to reset 2872 casio ?
If a Casio watch has a display readout that says "OPEN", the watch isn't closed properly. Check if all the parts are inside the watch and make sure the watch is tightly screwed shut. If the watch was serviced at a repair center you should return it to have it checked (for missing parts).
After 5 days of darkness, watch will not turn back on
The watch has a rechargeable power cell inside the cover. Remove the back, find the button batter, and replace it. It may be the old original or dead cell. Once you replace the cell, the watch will refresh and be back to normal. The only problem if that fails, the mini-computer brain died.
