stick it in dry rice. the rice should absorb all the water on/in the phone. this is not guaranteed to make the phone work again though nor will it guarantee the phone wont have any problems.
you can try a hard reset, but that method will reset the phone to factory settings and will delete all data on the phone so if you proceed with this method backup all data if possible and remove the sim card and any external memory cards.1. Remove the battery, wait for a few seconds, then reinsert the battery.2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
try hard resetMaster reset using hardware buttons: HTC Wildfire SVERSION 4 Created on: 15-Aug-2011 09:21 by tmo_brian- Last Modified: 07-Mar-2012 16:29 by tmo_josh_m
To perform a hard reset using the hardware keys, follow these steps:
Note: A hard reset restores the original factory settings and erases content, including downloaded ringtones, images, programs, and contacts stored in the internal memory. This feature allows for resetting of sound profiles, display settings, and phone or memory card settings. However, if you want to try resetting some factory settings without losing any data, then clear system cache before a master reset.
If the phone is plugged into the charger or USB cable, unplug it.
Remove the battery.
Important: Removing the battery is required. Turning off the phone with the Power key does not work, because of the Fast Boot feature.
Re-insert the battery.
Press and hold both the Volume Down key and the Power key. Do not release the volume key, continue on to step 6.
Release the Volume Down key when the three Android images appear on the bottom of the screen. The following options display:
FASTBOOT
RECOVERY
CLEAR STORAGE
SIMLOCK
Note: If you are stuck on a screen that says 'HBOOT' and 'FASTBOOT' without any other options to choose from, it means you have pressed the Back button. To get to the regular options, press either the Power key on HBOOT or the Back button.
Press the Volume Down key twice to select CLEAR STORAGE.
Press the Power key to initiate the master reset.
Press the Volume Up key to confirm Delete all user data.
Wait as the device clears the user data then restarts.
Only Telus can unlock it and only if the rent to own contract is paid off. If you take it to a third party unlocker, Telus can still lock it on you by using the IMEI number.I would urge you to edit out your IMEI number as it can allow the unscrupulous to clone your phone and make calls at your expense.
iPubsoft Studio recently announced that it released its new software -- iPubsoft Android SMS+Contact Recovery for Android program, a new program that helps HTC users retrieve lost message from HTC device, The program includes significant improvements like simplified operation optimization, can scan text message, contacts file.
Simple Tricks to Retrieve Deleted SMS Messages from HTC Phones
You can try GT Recovery for Windows!
GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Google+:https://plus.google.com/communities/109657948177651590858
Facebook homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
Download Link:http://www.gtrecovery.net/
You can try GT Recovery for Windows - the best data recovery software !
Accidently deleted some contacts on your Samsung Galaxy S6 ? A software can help you from big headache of Restoring deleted Contacts.
Here on video we Show you step-by-step guide to recover deleted contacts on android device with GT Recovery for Windows.
With this way you can recover deleted contacts on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Twitter:https://twitter.com/GtRecoveryapp
Facebook Homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
If the phone is frozen and you just want to "pull the battery" hold the power button for at least 10 seconds and the phone will power off(simulates a battery pull in devices with non removable batteries)
If you would like to do a factory restore(hard reset)
Ensure the device is powered off.
Press and hold the Volume Down button then press and release the Power button.
Note When the screen with the three androids appears, release the Volume down button.
Press the Volume Down button to select Factory Reset then press the Power button.
Note Allow several minutes for the reboot process to complete.
Let GT Recovery for Android get your photos back!
Lost your photos on Android phone & need to recover deleted pictures, try GT Recovery for Android - the World's 1st Data Recovery Software for Android smart phones.
It can directly recover deleted pictures, photos lost due to deleting, restoring factory settings, flashing ROM, rooting, etc., from SD cards inside Android devices. It let you preview the deleted photos before recovery. Watch the video tutorial to learn how to retrieve photos from Android phone easily with simple clicks.
Key features of Data Recovery - GT Recovery for Android:
Preview & selectively retrieve photos and video lost due to any problem
Support all Android phones/tablets, like Samsung, HTC, LG, Motorola...
Only read and recover the data, no personal info leaking, 100% safe
Twitter:GT Recovery
Download Link: http://www.gtrecovery.net/
This is a hard task to accomplish. First the text need to be converted by an optical character recognition system (OCR) to retrieve the text before it can be translated. The best app I found for this was from a review on android pdf readers.
They mention Documents to Go using it's built-in pdf reader to get the text from the pdf tile. "Ability to copy selected text to the device's clipboard and paste it into any other app" Although it is a paid app, the price is low and is extremely functional when working with all types of documents.
Once you have the text, you then need to translate it to your desired language. For this, google translator should be good enough: http://translate.google.com/
Once translated, it is your option(if legally allowed) to paste the translated text into a new document and modify to your liking.
I am unable at this time to find a useful android app which can do all of this and maintain the original pdf format and layout.
