20 Most Recent LG 42PX3RV 42 in. EDTV-Ready Plasma Television Questions & Answers
LG 42px3rv picture problem. When
Sounds like a bad Tcon board, most video but not all are caused by this board if the set has one, one other thing to check is the cables going to and from the Tcon board but be careful the LVDS cable and flat cables that go to the panel are very fragile
10/26/2017 8:23:24 PM • LG 42PX3RV 42... • Answered on Oct 26, 2017
Hi , i have a problem with a plasma LG 42PX3RVA, the set turns green when you press the power button but no picture or sound , i measure the voltage on the boards and found thay it was correct acco
Bulb overheated and probably blew, they are made of mercury most times so don't touch them they should be in a housing, that could be it. If most times dust gets in there and the fan gets weighted down with dust if its up against the wall no air flow, so there ya go, try that. good luck
6/6/2014 1:52:09 AM • LG 42PX3RV 42... • Answered on Jun 06, 2014
TV TURNS ON BUT NO DISPLAY AT ALL.
do a reset by manually holding down the power button, sometimes that works
1/30/2014 9:00:24 PM • LG 42PX3RV 42... • Answered on Jan 30, 2014
The channels memory is lost every time i switch it off
The main system memory IC is damaged. Even though this IC is a very small one, and cost more, replacing it is a skilled work, because, after replacement, you must have to enter its service mode options to adjust some data values there. Only an experienced service person can do this.
8/21/2012 2:07:42 PM • LG 42PX3RV 42... • Answered on Aug 21, 2012
0answers
No power, checked plug fuse ,fuse on power board
You need to do more indepth troubleshooting. Are you getting the any DC voltage in the primary AC side on the big cap(the one with 250~450dc rating).
Here are the service manuals that you will need:
http://elektrotanya.com/?q=showresult&megnev=LG%20&megnev2=42PX3RV%20&kategoria=&kat2=all
You also should check Z and Y sustain boards.
You have to at least get the DC standby voltage (3.3vdc or5vdc) for the processor the minute the TV is plugged in.
Please leave rating if it helps. You may also want to look through some of the LG PLASMA TV training manuals (look at any one of them since the operation concepts are all the same).
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
1/21/2011 4:18:49 PM • LG 42PX3RV 42... • Answered on Jan 21, 2011
0answers
Loud pop noise made lose
The loud pop was generated by the explosion of one of the capacitors from the power source. Open the back of the tv and replace all capacitors from the power source - if one has failed so badly  then the others can't be far behind. After that check what other components the failed capacitor might have damaged: rectifiers, coils and the IC's from the Y and Z -sus board.
Basic knowledge of electronics is required, if you don't have it then call a certified repairman.
8/29/2010 5:13:40 AM • LG 42PX3RV 42... • Answered on Aug 29, 2010
A thin blue vertical line has just appeared in
yes ss sent out a paper to us call for dervice there might be a wire loose
7/13/2010 10:23:00 AM • LG 42PX3RV 42... • Answered on Jul 13, 2010
What is the SKY remote code for model No RZ23LZ20
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
also check the below link -
http://www.skyuser.co.uk/tools/remotecodes/index.php
Thanks for using FixYa
Good Luck!!
3/27/2010 6:57:40 PM • LG 42PX3RV 42... • Answered on Mar 27, 2010
My plasma tv has just lost it's picture. I do have
There will be a fault in either the Y or Z sustain boards, these are responsible for driving the screen 9hence sound but no picture). The popping sound willhave either been a fuse blowing on the board or another possibility is one of the drive ICs on the buffer board has blown. If so it's best to replace the board.
3/21/2010 8:22:12 PM • LG 42PX3RV 42... • Answered on Mar 21, 2010
My plasma just stopped working, no pic or sound or
I just fixed this very same problem. It is the capacitors that are the problem. I think that if you have some minimal skills with
soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right.
The bad capacitor(s) will be bulging at the top. The ones that go bad are 1000 microfarad 10 Volt, however you can replace them with
the higher 16 volt. I got the capacitors from maplins, 24p each. You just need to de-solder out the bad ones and then put the new
ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board.
solder the 2 new parts in then just cut off the ends off the capacitors.
11/2/2009 6:10:22 PM • LG 42PX3RV 42... • Answered on Nov 02, 2009
LG 42PX3RV 42 in. EDTV-Ready Plasma Television Logo
37 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
plasma just stopped working no pic or
  • Televison & Video
