20 Most Recent
D-Link WUA-2340 (ASKU55774) Wireless Adapter Questions & Answers
I have a D-Link DIR-825
The D-Link WUA-2340 is an 802.11g adapter. This means that 54mbps is the fastest that it can run. It is backward compatible with the 802.11b standard which runs at 11mbps. However, it is not forward compatible to 802.11n. You need to get the DWA series from D-Link (I'm guessing you have a preference for D-Link). This should run your D-Link DIR-825 at 100mbps +. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/mark_1e5d703456353ef9
How to install
First :
- Insert cd installation d-link
- Click setup
- After finish, plug your d-link wirelles
- windows may detect this wirelles
- Finish
-Thx
Tried to install d-link wifi
Good day. In regards to your problem regarding the Error number 0x80004005 usually this is an error you get due to some anti-virus installed on your system. This error is usually related to email if your using an email client like outlook express or windows mail.
Solution:
Try to make sure that you're anti virus setting is not high or just set it to medium. Check also firewalls make sure its not blocking your connection.
Hope this will help you a bit. Thanks for choosing Fixya.
The D-LINK ASK FOR A KEY TO CONNECT
It's the passphrase to connect to your encrypted router. If you can't remember the correct character string you once set to your router, you'll have to login to its web utility and change it. In case you happen to not remember how to do it either, please, tell me your router's model and version. I'll try my best to fetch those informations for you.
Hope to hear from you soon.
Regards,
Carlos
Need driver for WUA-2340 can you help
Scratch that request, the latest driver for your device supports Windows 2000 up to Windows Vista 32 and 64-bit. Download the driver below:
ftp://ftp.dlink.com/Wireless/wua2340/Drivers/wua2340_drivers_150.zip
I got this adapter yesterday. i am able to get a
Did you also get a CD-ROM containing the D-Link software, to add support for this device into your computer? Insert the disk, and run the "installer" for the device-drivers.
Do you know the SSID ('name' of the wireless network) for your Intranet? Do you know the password for that network?
Talk to your local system-administrator, for help in connecting to your private Intranet.
I've tried all the repairs
Disable the anti-virus and try restore your PC on last known good configuration. Let me know after primary test.
My internet cuts in and out with this adapter
mcdevito75 here, I also have wireless with the same or similar problem, we need I think 4 sattelite hook ups for wireless to work any less, we get not recongnised or pull the plug for 10--20 secs. and try reconnect. I simply hit my computer re-start. Click on Start, then re-start.
