20 Most Recent Sony Ericsson Cyber-shot K800i - Velvet Black unlocked Mobile Phone Questions & Answers
Unlock phone code
Is your phone locked with any particular network?I suggest you can approach Mobileunlocksolutions.com and specify the country,locked network of Sony Ericsson Cyber shot K800i.Based on the availability you can get the unlock code along with free instructions.
4/7/2014 11:20:51 AM • Sony Ericsson... • Answered on Apr 07, 2014
Sony Ericsson K800i Phone. Please, the camera is not working. Is there a code to turn it on?
Question edited for clarity. Question moved to correct category. No, there is no code. It needs repairing. https://www.google.com/search?q=Sony+Ericsson+K800i+camera ..
3/27/2023 4:56:25 PM • Sony Ericsson... • Answered on Mar 27, 2023
My Cell Phone volume is very quiet and the speaker option ineffective, how do I fix this?
ringer speaker defective ,should be change by an expert
6/3/2015 11:17:20 PM • Sony Ericsson... • Answered on Jun 03, 2015
Hi , I have a phone lock on my old Sony Ericsson
Three wrong pin codes and you have to give in the puk. The original pin and the puk came with the sim provided with the phone. Perhaps you still have the paper with both in the box? or perhaps you saved the contract with that paper? If you enter the puk, you can choose a new pin.
7/18/2014 8:19:23 PM • Sony Ericsson... • Answered on Jul 18, 2014
Code reset button
What are you trying to do ? I hope some of this helps. .......................................................................................... button 12 menus appear that are unique to the Sony Ericcson k800i ... K800i Secret Menu In this post I will write about a few hidden features of the K800i. These codes should work on most Sony Ericsson models though, try for yourself. ......................................................................................................... Service Menu The Service menu can be accessed by pressing the following sequence while in the standby screen: right, *, left, left, *, left, * The phone now shows a menu titled 'Service' with 5 menu items:
  • Service info : Here you can view information regarding your handset such as the model number, software versions (firmware as well as other versions, like camera driver version, etc.)
  • Service Settings : Here you can switch USB charging on or off
  • Service Tests : Allows you to test every component of your phone, such as the keypad, microphone, speaker, LED, Display, etc. Any fault can be found out easily with this method. In this section, You can also check the Total call time, the number of hours you have called.
  • Text Labels : Better leave this section alone.
  • Discharge Flash : To discharge the camera flash fully.
In addition to the Service Menu, SE's also offer a 'Personalize' menu. It can be accessed by the sequence left, *, *, left But unlike the Service Menu, the Personalize menu is for trained experts only. So it's better not to tinker with these settings. Still, it's cool to know your phone's got all these things under the hood right? --- Want to see something cool? Access the ServiceMenu. Now Navigate to Service Info > Model Info. While the Model is displayed, press the folowing key sequence : 2, 4, 6, 8 \m/ SE \m/ .......................................................................................................... Stop thieves running up huge mobile bills by locking your Sony Ericsson K800i and protecting it with a PIN To protect your phone from unauthorised use you can set a phone lock to stop others using it. The default phone lock code on the K800i is 0000, so it is best to change this number to one you can easily remember in case it is lost or stolen. To change your unlock code:
  • From the Menu screen, select Settings (Figure 1).
  • On the General tab, scroll down to Security (Figure 2).
  • Select Locks (Figure 3) and then Phone Protection (Figure 4).
  • Select Change Code (Figure 5).
  • Enter the default code then enter (And re-enter) your new one (Figure 6).
Once you have changed your phone lock, you can then set to either On, Off or Automatic (Figure 7). When it is turned On, you must enter your code when you turn the phone on, Off means you don't need to enter a code. Automatic means that you only enter the phone lock code when a new Sim-card is inserted into it.
4/13/2014 2:10:14 PM • Sony Ericsson... • Answered on Apr 13, 2014
0answers
Format
Be the first to answer 4/7/2014 7:01:23 AM • Sony Ericsson... • Posted on Apr 07, 2014Be the first to answer
Initialization failed
If your Sony Ericsson K800i phone displays an error message saying "Initialization failed " when you inserted your sim card then your phone is probably sim locked.To unlock it permanently visit the site Unlocking4U.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it. http://www.unlocking4u.com/sony-ericsson-k800i/rs5wp9/
1/10/2014 5:29:55 AM • Sony Ericsson... • Answered on Jan 10, 2014
Sony ericesson k810i emergency call only
If your Sony Ericsson K800i Mobile Phone says "Emergency calls only" then it is probably locked with network.Don't worry you can it easily by using an unlock code.To get this code at low cost visit the site ClassicUnlocking.com with easy step by step unlocking instructions and unlock it.After unlocking it,you can use freely any GSM network SIM card.This is the safe,fast and permanent unlocking method.
8/17/2013 12:16:50 PM • Sony Ericsson... • Answered on Aug 17, 2013
0answers
Country lock
You can remove country lock of your phone using unlock code.You can get the unlock code for your Sony Ericsson K800i mobile from ant third party online vendors like Unlock-Zone.com here you need to specify your country,Network provider to which it is locked,IMEI number of your phone.Then they deliver unlock code to you through mail with unlocking instructions.
6/29/2013 10:14:48 AM • Sony Ericsson... • Answered on Jun 29, 2013
0answers
NETWORK ic
its best you take it to a technician to replace the ic
5/30/2013 12:00:57 AM • Sony Ericsson... • Answered on May 30, 2013
0answers
3answers
I can't power on my Sony Ericsson W200i!
Seems Battery is not fully charged. Try to charge battery using universal charger then try to switch on the phone.
1/28/2024 5:16:09 AM • Sony Ericsson... • Answered on Jan 28, 2024
Sony Ericsson Cyber-shot K800i - Velvet Black unlocked Mobile Phone Logo
2 questions posted
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
K800i Sony Ericsson
  • K800i Sony Ericsson
Most Popular Question
unlock phone code
  • Cell Phones
