20 Most Recent Whirlpool LEQ9858P Electric Dryer Questions & Answers
Kenmore 110 element wont shutoff
Hi, You have a ground short to the element, so either the element is broken and touching the case or you and a wire touching ground around the element. Either way unplug this unit and check for a short wire from the back of the unit. Safety first!! Good Luck Gere I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
4/13/2014 3:29:34 PM • Whirlpool... • Answered on Apr 13, 2014
Elements stays on all the time
Gat a repair men. if the element is on when the fan is not blowing severe overheating can occur
4/13/2014 4:14:58 AM • Whirlpool... • Answered on Apr 13, 2014
Whirlpool LEQ9858PW0 Buzzes But Won't Start.
sounds as if wither you have a bad motor assy, or something haas fallen down into the "blower assy" preventing the motor form spinning.. in the back wher eyou tested your fuse, just to the left of that you see a large tubular housing (rounded on bottom", thats the cover for the blower , i believe its 3-4 screw holding it on, nad also the 2 screws visable when you remove the filter assy, the housing will pull off( you may need to wiggle it abit) and hopefully youll find a sock or something jammed in the blower assy
12/6/2013 8:06:43 PM • Whirlpool... • Answered on Dec 06, 2013
Leq9858lwo belt
I am not sure. In the appliance industry we do not measure the belts as most all dryers take a different belt. Part number for your dryer belt is 341241 and cost through us would be 10.95 + shipping of 5.95. Should you choose to order, follow this link to our website where you can scroll down and fill out the secure order form to process your order. https://www.affordableappliance.com/orderform.php If you have any problems, concerns or need further information, feel free to reply to this email or for Parts Order Only, call 570-622-6441. Keep in mind ordering through us helps continue this free on-line help available for you and many others. Help those that help you. Waiting to hear from you,Eric & Ann Campion
11/6/2013 12:18:09 PM • Whirlpool... • Answered on Nov 06, 2013
Leq9508pwo
Most likely the heating element is burned out. Could be the thermal switch or thermostat.
8/8/2013 12:00:09 AM • Whirlpool... • Answered on Aug 08, 2013
Whilpool dryer LEQ9858LWO takes to long to dry
Have your checked your lint screen? It could be clogged if you use a lot of fabric softener. Take it out and wash it using a stiff brush to remove the waxy buildup on the screen.
5/22/2013 11:52:22 PM • Whirlpool... • Answered on May 22, 2013
Whirlpool Dryer LEQ9508PWO drum will not turn
the motor is either jammed or needs oiling in the bearings
12/30/2011 6:27:51 PM • Whirlpool... • Answered on Dec 30, 2011
Dryer just stop running , i checked breaker and
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
9/11/2011 2:11:24 AM • Whirlpool... • Answered on Sep 11, 2011
Moisture inside dryer, how to
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
8/10/2011 10:55:32 PM • Whirlpool... • Answered on Aug 10, 2011
Whirlpool LEQ9858P Electric Dryer Logo
122 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
leq9858pw1 get instruction
  • Dryers
