20 Most Recent
IOGear GPSU21 Print Server Questions & Answers
I have windows XP and
Sorry. You will find that Windows XP will not function right because Microsoft no longer supports it.
A minor problem, but annoying
change paper size setting as the printer may be set to a shorter page and that is why it is not ejecting
if nothing works then always print an extra page
it will run through the printer untouched
I can print a test page on my LJ HP1006, but it will not print on the print command
do u have it set up on your computer , it will need the software in order for it to work , usually your computer will find and install the needed software depending on the age of your computer or laptop , if it does not you have to goto the printers website and download the software for your model and once it is downloaded you will have to open it , hope this helps
Iogear print server not compatible with windows 7
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
IOGear GPSU21 doesn't work wirelessly with ip4500.
First, you have to make sure that the printer can print directly connected to the computer.
Second, make sure that you can "ping" the print server while it's connected to the router.
If the printer works when connected to the computer and you can ping the print server, then you just need to change the port in the print server utility. It should be set to LP1 and not LPT. The queue name should be set to L1.
Check also the printer port, and be sure that it's set to USB001 or USB002 Virtual Printer Port.
If same problem occur, try to uninstall and re-install the server utility. Use the link below to download the utility for Vista 64-bit OS:
http://www.iogear.com/support/dm/driver/GPSU21#display
You may refer to the user manual of GPSU21 or call IOGEAR through 866-946-4327.
Thank you and good luck!
Cannot print from one of my laptops. only
I would suggest deleting the printer and then adding it again.
In worst case, if you cannot re-add the device, share the printer from another computer and then add the shared printer.
I am using A Iogear gpsu21 with a Kodak esp5
First, make sure that the Kodak printer driver is properly installed in your Sony Vaio. Make sure that you can print while the Kodak is directly connected to Sony Vaio.
If you can print directly connected to it, try to reinstall the GPSU21 Utility.
Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
