You will need a pre amp that supplies whats called phantom power which is power that feeds the mic ..
This will come from either mixers [small cheap ones..but check it has XLR mic input with phantom power] or from a stand alone pre amp or audio interfaces with built in inputs for mics with phantom power..
Also you will need an XLR mic lead..Buy a good one with neutrik plugs or similar..
Hello Sampson
People ask questions. Experts answer them. No one get paid, people answer just for the joy to be able to help others.
People who use AI Chat GPT to answer, people who answer just for points get deleted. Points are for fun.
It isn't a 'program', it is a peer to peer self help website.
ADMIN Andrew
There could be several reasons why your Samson Airline CR77 receiver is not producing any output:
Volume levels: Ensure that the volume levels on the receiver are turned up and not muted.
Output mode: Check if the output mode on the receiver is set to the correct mode (balanced or unbalanced).
Cables: Make sure that the cables used to connect the receiver to the sound board are functioning properly and are plugged in correctly.
Interference: Check if there is any interference from other wireless devices operating in the vicinity. This can cause signal dropouts and affect the receiver's output.
Dead batteries: Check if the batteries in the receiver are charged or need to be replaced. A low battery can cause a drop in output.
If none of these solutions work, you may need to contact Samson's customer support for further assistance or consider taking it to a professional technician for repair.
Any that can plug into the unit. The quality of the sound will depend on what you are willing to pay for the microphone.
I would take the unit to a shop that sells microphones and they will be able to get you a right one for the unit.
Hi, have you tried the G-Track Pro on another computer, to see if it repeats the fault?
I sent you the link so you can download the user manual of your Samson
I hope you can solve the problem
Greetings Franco Dosil
Hola, has probado el G-Track Pro en otra computadora, para ver si repite la falla?
Te env?o el link para que puedas descargar el manual de usuario de tu Samson
Espero puedas solucionar el problema
Saludos Franco Dosil
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=mine&fml=0&brd=0&p=2&thid=27347935#
