20 Most Recent
KitchenAid KESS907SSS Electric Kitchen Range Questions & Answers
Mother board
I also have an issue in this area. My buttons and timer now ring at a very low volume. I need an external timer instead of the built in timer because you will never hear it if you aren't standing next to it. I have read that possibly the use of the oven cleaner causes heat stress that hurts the motherboard..
My Kitchenaid range starts by itself. I am
I have recently heard of a woman starting a class action lawsuit in Vancouver bc supreme court check that out it may be related to your unit. other wise check the auto start function if it is faulty then get rid of unit asap for your safety
Cant get pizzacrust done without almost burning
if using all 3 racks and pizza is on top rack could be the problem. also watch to see have often bake element comes on. if bake element isn't come on and the broil element is coming on could be a bad mother board
KitchenAid Stove KERS205TSS 2 light issues.
The issue with the oven display light and the oven light on the KitchenAid Stove KERS205TSS 2 may be related. The problem with the oven display light could be due to a faulty control board or a malfunctioning light switch. The control board may need to be replaced if it is not sending a continuous signal to keep the light on. On the other hand, if the light switch is defective, it may not be able to maintain a connection to keep the light on.
The issue with the oven light staying on could also be due to a faulty light switch. If the switch is stuck in the "on" position, it will not turn off even when the door is closed. This can cause the bulb to burn out prematurely and waste energy. To fix this issue, you may need to replace the light switch.
It is possible that both issues are related and caused by a malfunctioning control board. If this is the case, replacing the control board should fix both problems.
To fix these issues, it is recommended to contact a certified technician or an authorized service center for KitchenAid appliances. They will have the expertise and tools necessary to diagnose and repair the stove safely and effectively.
