20 Most Recent Amana 19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW Questions & Answers
Explain how to refill R134 freon
you should not refill freon, first because it is illegal. second, if you need a recharge it will just leak out again. third, to do it correctly will require braising with an acetylene torch.
11/6/2013 2:29:40 AM • Amana 19.7 cu.... • Answered on Nov 06, 2013
How to refill R134 Freon
you have first put in a line tap. If the freezer system has been open it must be put in vac. to get moisture out. Then with interior coil exposed put in a few oz and start compressor. with compressor running add while watching interior coil/ you add slow til coil frosts to 3/4 then your done If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_4ed9a6c8e57209e6
10/27/2013 12:19:13 PM • Amana 19.7 cu.... • Answered on Oct 27, 2013
2answers
I have lost my turnkey for an Imperial Upright
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
8/3/2012 7:07:17 PM • Amana 19.7 cu.... • Answered on Aug 03, 2012
I had to lay down
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
8/7/2011 6:25:42 PM • Amana 19.7 cu.... • Answered on Aug 07, 2011
It is frosting up pretty good inside, we are
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
4/23/2011 6:29:53 PM • Amana 19.7 cu.... • Answered on Apr 23, 2011
We sold a freezer, it
if they moved it on it's side they damaged the compressor,the machine shouldn't be laid on it's side.if they let it sit for a few days it might have recovered.if it wasn't laid on it's side a wire could have been knocked off somewhere,hard to say without being there to look at it.
4/9/2011 8:31:24 PM • Amana 19.7 cu.... • Answered on Apr 09, 2011
Our freezer is a self-defrosting
Either you have a leaking door gasket,The freezer door is being held open,or the defrost time clock is not turning
9/16/2010 4:53:36 AM • Amana 19.7 cu.... • Answered on Sep 16, 2010
Ice cream will not stay cold in freezer. melts
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
8/16/2010 1:50:49 AM • Amana 19.7 cu.... • Answered on Aug 16, 2010
19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW: the upright freezer was on its back for about 8 ho...
It is usually reccomended to let it stand in it's normal position for 24 hours prior to running to allow any oil to run back to the compressor. Unit should work.
5/21/2010 4:41:44 AM • Amana 19.7 cu.... • Answered on May 21, 2010
Can an 3.5 cu ft freezer be layed on its side for
yeh u can...coz company made it wid dis quality
2/26/2010 3:53:14 PM • Amana 19.7 cu.... • Answered on Feb 26, 2010
2answers
Have an old deep freeze that need to get rid of
dont cut the freon lines inside your hause, it stinks!
all you can do it take off the door and any other bits inside it, its still going to be darn heavy, find a trust worth strong guy give him a drink to move it for you
10/23/2009 9:32:01 PM • Amana 19.7 cu.... • Answered on Oct 23, 2009
2answers
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
11/22/2008 9:06:41 PM • Amana 19.7 cu.... • Answered on Nov 22, 2008
2answers
Amana bottom freezer, all working OK, but very noisy freezer. How do I fix it?
There are a few potential causes of a noisy bottom freezer. Here are some things you can try to fix the problem:
  1. Check for frost buildup: Frost buildup can cause the freezer to become louder as it has to work harder to keep things frozen. To check for frost buildup, remove all items from the freezer and unplug the fridge. Then, use a hair dryer to melt any frost that has accumulated on the evaporator coils (usually located behind the back panel of the freezer).
  2. Check for loose parts: Some common sources of noise in a freezer are loose screws, washers, or other small parts. Check for any loose items and tighten them as needed.
  3. Check the evaporator fan: The evaporator fan is responsible for circulating air within the freezer. If the fan is not working properly, it can cause the freezer to become noisy. You can check the fan by removing the back panel of the freezer and listening for any unusual noises. If you suspect the fan is the problem, you may need to replace it.
  4. Check the compressor: The compressor is responsible for circulating refrigerant and cooling the freezer. If the compressor is malfunctioning, it can cause the freezer to become noisy. You can check the compressor by listening for any unusual noises or by checking the compressor with a multimeter. If you suspect the compressor is the problem, you may need to replace it.
If you are unable to fix the problem yourself, you may want to consider contacting a repair service. They will be able to diagnose and fix the issue more accurately.
1/4/2023 5:58:02 AM • Amana Freezers • Answered on Jan 04, 2023
AMANA UPRIGHT 11.8 Cu.Ft. deep freeze model# ESUF15HW. Only freeze at the bottom. food on top and middle shelves defrosted.
Check the seal. Close door on a piece of paper, see if seal grabs it
6/10/2019 1:36:58 PM • Amana Freezers • Answered on Jun 10, 2019
I have an amana refrigerator model #sxd22s2w. The
Seems like a clog somewhere calcium deposits
3/18/2019 9:15:43 AM • Amana Freezers • Answered on Mar 18, 2019
Amana 19.7 cu. ft. / 558 liter Upright Freezer Deepfreeze AFU2004AW Logo
18 questions posted
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you an Amana Freezer Expert? Answer questions, earn points and help others
View Most Popular
Amana Freezers
  • Amana Freezers
Most Popular Question
  • Freezers
