20 Most Recent
Kenwood KAC-9103D Car Audio Amplifier Questions & Answers
Power keeps cutting in and
Sounds like u have some blown output transistors possibly. Check all connections especially Ground! If no luck have ur local repair technician have a look at it.
6/1/2014 12:38:38 AM •
Kenwood...
Answered
on Jun 01, 2014
No sound
Sounds like the bumby road may have made ur output wires touch and short out some output transistors in ur amp. Or ur amp has bad solder connections. Either way have ur local repair technician have a look at it
6/1/2014 12:16:52 AM •
Kenwood...
Answered
on Jun 01, 2014
Replace rca ports in an amplifier
Have ur local repair technician have a look at it. It may just be bad solder connections on the board where the rca jacks are connected. If not order them and have a tech. Put them in
6/1/2014 12:08:29 AM •
Kenwood...
Answered
on Jun 01, 2014
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
11/16/2012 7:26:26 PM •
Kenwood...
Answered
on Nov 16, 2012
Two questions. 1) can my amplifier over-power this
No, your not over powering your L7, your underpowering your subwoofer.
Your Kenwood is
500W x 1 at 4ohms [20-200kHz 0.5% THD]
900W x 1 at 2ohms [100Hz 1.1% THD]
Your L7 is:
Max Rec Amplifier Power (WATTS PEAK/RMS)*
2000/1000But its ok for your subwoofer, alteast your not giving it to much stress. But personaly, get another mono amplifier that would match your subwoofers rating.
4/8/2011 5:42:48 AM •
Kenwood...
Answered
on Apr 08, 2011
KAC-9103D hooked up to two 12
My best guess is that it would be your ground wire or even the power into your amp. I would check all the connections going to and from your amp
3/12/2010 5:09:18 PM •
Kenwood...
Answered
on Mar 12, 2010
KAC9103d been running great for a year, factory
Could be that you have a partially roasted(blown) coil on one of your subs which will function- but will keep tripping your amp.You can check that out just by using a different set of subs to listen to and by the process of elimination if the problem goes away then you know where the problem is at.Also check your gains you might be riding the gain a little high which causes distortion which causes heat(FAST) which will cause the amp to shut down completely or some amps will decrease output in a programmed attempt to save itself.turn the bass boost down to half if you even use it at all- that too can cause massive distortion in the amp itself,meaning only that if you have the bass boost on your deck turned up and then you turn the boost up on your amp the sound signal is then WAYYY distorted which will cause a thermal shutdown too. Last thing is to make sure that your subs arent running below 2 ohms because i believe that particular amp is designed to put out about 900 watts at 2 ohms.good luck
1/30/2010 7:53:33 PM •
Kenwood...
Answered
on Jan 30, 2010
Why does the kenwood kac-9103d has two sets of
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
9/23/2009 10:44:08 PM •
Kenwood...
Answered
on Sep 23, 2009
Power from the kenwood 9103D to the Kicker comp 15's is on n off
Most times I hear of people turning up the volume on a head unit and cutting off on the amp it tends to be wired to a speaker with the wrong impedance. I googled kicker comp and got tons of different models, not to mention almost all of them were 250 watt rms. That amp is 900 watt RMS at 2 ohms. If you only have 1 woofer, you can't possibly wire it wrong being all the subs I've seen in the results were 4 ohm. If you are using just one though, you should get a larger speaker, both 2 ohms and 1000 watt rms to prevent distortion. I'm afraid I can't answer your post without further information on the sub you are using.
8/3/2009 11:29:02 PM •
Kenwood...
Answered
on Aug 03, 2009
