20 Most Recent
Teac GF-650 Turntable Questions & Answers
CD drawer will not open
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
B210 belt
If you have the original measure the Diameter in mm and also the width in MM. You don't have to be spot with these measurements. Then put the words "turntable belt XXmm (diameter) into Google. You should find something, you can narrow it down by adding the width, but I would just try the diameter first. If you need to remove the belt make a note of how it fits first!
Teac turntable plays too fast
This sounds like a motor speed control problem. It could be either the motor itself or an electronic fault. So unless you know a bit about electronics and know how to use a soldering iron etc, then the answer to your question is no.
Turntable runs a bit too fast
LOL, The Chipmunks rock!..j/k
Sounds your player isn't reconizing your settings, therefore the switch that controls them could be shot.
Firstly consult the troubleshooting section of your manual
If you have have no manual to reference, check this site for a downloadable one.
If still no, then visit the Teac home page and follow the support/troubleshooting/customer service links there.
There also you will find listings for any authorized repair shops in your area where you can have it looked at and a new switch installed, should that indeed be the issue.
Conversely to that, call the toll free number you will find in your manual or on their website for assistance.
Wishing you luck and... no more Chipmunks...
Teac GF-650
hi, please if you can open the turntable unit ,go on the part of power supply please double check the fuse first...maybe that is the solution for your problem...find the supply section ... you can find it from the AC plug going to the deck end..u
GF-350
is it possible to fit a new laser unit to my GF350
Volume
LPs were mastered back in the day with no real volume standard--ceertain sounds had to be mastered light because the engraving on the master disc was so sensitive.....digital technology does not have that problem....digital takes a lot of volume before it starts to break-up...
rick12string
Is the Teac CR-H100 a unit that can be repaired?
The repairability of the Teac CR-H100 depends on the specific issue it's facing. Many electronic devices, including audio units like the Teac CR-H100, can be repaired if the problem is identified and if replacement parts are available. It's recommended to contact Teac customer support or a certified technician to assess the specific issue and determine the feasibility of repair based on the unit's condition.
Teac NP-H750 takes a long time from powering at wall to going into standby / ability to switch on.
Here are some troubleshooting steps you can try: Power source and wiring: Make sure you are using a reliable power source and the correct power cord for the Teac NP-H750. Sometimes using faulty outlets or wiring can slow down the power on time. Firmware update: Check if there is a firmware update for the device. Manufacturers regularly release firmware updates to fix performance issues and improve performance. Updating the firmware can help fix the slow power-on. Reset the device: Try a factory reset on the Teac NP-H750. This process can help eliminate any software bugs that may be causing the slow startup. Network connection: If your Teac NP-H750 is connected to a network, check the network settings to make sure you have no problems connecting to the Internet. Sometimes network issues can delay the startup process. Check for hardware issues: Inspect the device for any damage or loose connections that could cause a delay during power on. Check the power button and other controls carefully for proper operation. Power saving system: Check the power saving system on the Teac NP-H750. If the device is set to quickly go into standby mode, it may take longer to turn the power back on. Use Support: If none of the above solutions work, consider contacting Teac Customer Support or their Authorized Service Center for further assistance. They may have specific troubleshooting problems or know general issues with your model. Please note that products must be made with care, as modifications to the product or unauthorized repair attempts may void the warranty. If your Teac NP-H750 is still under warranty, it is best to contact the manufacturer
