20 Most Recent
Bose Companion III Computer Speakers Questions & Answers
Creative Inspire 5300 Volume Control broken!
For those searching the answer "How to replace/repair Creative Inspire 5300 volume control":Its simple : looking at the back of the suboofer, the pins are as follows from top right, clockwise : LED VDD , Balance pot middle leg, GND, pots + legs, Volume pot middle leg, on switch input. Connect one pots ends to GND and the other ends to pots +, connect a switch on GND and on switch input, anode of led to LED VDD, cathode to GND (there is a 1,8k resistor inside so no external resistor needed)
Speakers wont work
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Volume not working,green light on
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Speakers will not work on
The system requirements for this are:
1 GHz, minimum, Pentium processor or equivalent
256 MB RAM, minimum
Microsoft Windows XP or later, or Mac OS X 10.4.6 or later
Is you OS Mac OSX 10.6.6? If so then it seems that yo have a more recent version of Mac OSX so it's not that.
Have you tried any other speakers in your iMac, do they work? If they don't then it may be that your audio port on your iMac is faulty.
You can view the setup manual to guide you with the connecting up of the wires, you can see it here. It might just be a loose connection.
I also suggest trying it in another system to check that it works properly just in case.
My Bose Companion III Computer
This may sound obvious and you might have checked this already, but check all of your mute keys. If the speaker's volume control is down, that's one. If there's one on your keyboard you could accidentally hit, that's one. If the sound properties on your computer insist sound is coming out, try a different set of speakers, or try the speakers on a different device like an iPod. Get back to us if you still have problems. Hope this helps =]
