20 Most Recent Kyocera FS-C5030N Led Printer Questions & Answers
Replace toner clean printer command
If your Lexmark printer is displaying the message "replace toner clean printer," and you have already checked that the toner is full, there might be an issue with the toner cartridge or the printer's sensors. Here are some steps you can take to troubleshoot and potentially resolve the problem:
  1. Remove and Reinsert Toner Cartridge: Turn off the printer and open the front cover to access the toner cartridge. Carefully remove the toner cartridge and then reinsert it firmly into the printer. Make sure it is seated correctly in its slot.
  2. Check for Obstructions: Inspect the printer's interior for any paper jams, debris, or other obstructions that might be interfering with the toner cartridge or the printer's sensors.
  3. Check Toner Sensor: The printer has sensors that detect the toner level. Sometimes, these sensors can become dirty or malfunction. Locate the toner sensor (usually a small window or sensor on the toner cartridge) and ensure it is clean and not obstructed.
  4. Reset Printer: Turn off the printer, unplug it from the power source, and wait for a minute or two. Plug the printer back in and turn it on again. This can sometimes clear temporary errors.
  5. Check Toner Cartridge Contacts: Ensure that the contacts on the toner cartridge and inside the printer (where the toner cartridge makes contact) are clean and free from dirt or toner residue.
  6. Check Printer Settings: Verify that the printer settings are correctly set to recognize the installed toner cartridge. If the printer allows you to manually set the toner cartridge type, make sure it matches the actual cartridge installed.
  7. Update Firmware: Check if there are any firmware updates available for your Lexmark printer. Updating the printer's firmware may address known issues and improve printer performance.
  8. Try a Different Toner Cartridge: If you have access to another compatible toner cartridge, try using it in the printer to see if the issue is specific to the current cartridge.
8/6/2023 1:34:32 PM • Kyocera... • Answered on Aug 06, 2023
Call service Code 4600 KYOCERA FS 8520 MFP
LSU cleaning motor error
When the LSU cleaning motor
is driven, an error signal is
detected continuously for 1 s.
Defective connector
cable or poor
contact in the connector.
Reinsert the connector. Also check for continuity
of the connector cable. If none, replace
the cable.
5/27/2019 10:53:29 PM • Kyocera... • Answered on May 27, 2019
DIRTY PRINTS
check the fuser or drum with out seeing the copies its hard to tell for sure
8/6/2014 7:01:57 PM • Kyocera... • Answered on Aug 06, 2014
Open the fuser for FS-C2126 MFP
there is a blue mark on the right side of the fuser simply pull it towards you and that should allow you to see the rollers and remove paper if not its four screws and three connectors to remove the whole fuser
7/10/2014 9:36:05 PM • Kyocera... • Answered on Jul 10, 2014
0answers
Error message 7001:0078336
please replace cartridge chip
5/10/2014 1:17:13 PM • Kyocera... • Answered on May 10, 2014
Error Msg 7001:0078336
replce the toner chip
5/10/2014 1:16:13 PM • Kyocera... • Answered on May 10, 2014
0answers
0answers
Will not print
Be the first to answer 2/15/2014 3:06:07 AM • Kyocera... • Posted on Feb 15, 2014Be the first to answer
tip
Toner Box full when its not - fault
Putting a small lump of bluetac on the inside of the door will push the waste toner collection box into the correct position and stop the empty the toner box fault. As the toner box is not seating in the sensor correctly.
0answers
Black page printing
please open drum unit and there you can find a unit called charge unit inside this one thine wire is coming clean that wire and check ...... if you want full details please chat with me ... my ID [email protected]
6/14/2013 12:42:52 AM • Kyocera... • Answered on Jun 14, 2013
Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
12/12/2012 2:24:30 PM • Kyocera... • Answered on Dec 12, 2012
2answers
Kyocera FS-C5030N KX firmware update tool
you are overcomplicating it... all you need is a compact flash card big enough for the firmware... then you upload the firmware to the card and stick the card into the printer... but first power down printer and plug it out and then turn it on and follow the display... it will prompt you
here is the steps...
you will see ready
then press menu... arrow down to memory card
press forward arrow
you will see format
press enter
you will see processing
when its finished
you will see ready...
turn off machine... unplug it...
pull out compact flash
plug machine in
turn it on...
the **** for the compac flash is on the right hand side at the bottom by the ventillation opening...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
10/27/2012 5:32:10 PM • Kyocera... • Answered on Oct 27, 2012
Kyocera FS-C5030N Led Printer Logo
72 questions posted
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
FS Kyocera
  • FS Kyocera
Most Popular Question
changed blue toner now prints
  • Office Equipment & Supplies
