20 Most Recent
Foxconn 661MX Motherboard (FOX661MXMB) Questions & Answers
Submit vga sis661mx v1.0
hi there, do tell if you don|t know
- where the slot for the graphic adaptor is on that board or
- you don t know who made the graphic card or
- the board itself does not recognize the already inserted graphic card
please give more details!
whew, look in BIOS or download pcwizard2008 to tell you more about your system,
good luck
Will windows 7 install useing
I have found Windows 7 to be the easiest operating system to install but you need to have a minimum of usually 1 gig of ram. I have gotten it to work with less but it is slow.
Just make sure you are connected to the internet with a Ethernet (network) cable so windows will find and update all your drivers.
Back up and save all important information before starting, and do a clean install. I have used the Windows 7 file and transfer wizard which is easy to use. I have attached that link below.
http://windows.microsoft.com/en-US/windows7/products/features/windows-easy-transfer
If I can be of any more help let me know,Thanks for using FixYa
I can't configeration the sound
Hello.
- You can get the sound drivers for your motherboard from this site: http://www.foxconnsupport.com/download.aspx?models=en-us0000114&category=C000000001&series=en-us0000001
- You can get the rest of the vital data that was contained on that disc via this site: http://www.foxconnsupport.com/download.aspx?models=en-us0000114&category=C000000001&series=en-us0000001
Hope that was helpful. Have a good day.
Hi, i want to no,
It is Firewire port/ Interface. The IEEE 1394 interface is a serial bus interface standard for high-speed communications and real-time data transfer, frequently used by personal computers, as well as in digital audio, digital video applications etc. The interface is also known by the brand names of FireWire (Apple), i.LINK (Sony), and Lynx (Texas Instruments). This is not as widely used.It works just like USB but it is meant for connecting Firewire capable devices. If you have any firewire capable device (like video camera)and firewire cable, you can connect the device to your PC and use it for high speed data transfer.
Hope it helps! Good Luck!
CreativeTECH
Freezing or Jumping Mouse Pointer
This could happen if the PS/2 connector on the motherboard is defective, or if there is a failing component in the PS/2 circuitry on the motherboard.
Could also be due to loose solder points at the PS/2 connector.
This needs to be checked by a qualified technician.
Problem when running games
Sounds very much like the capacitors are gone.
Have a close look at all the capacitors.
I think you will find some that have bulged at the top, may or may not be leaking brown liquid.
If they are, look at it as an opportunity to get a better board!
N15141 drivers
N15141, is not a model is Australian elect, certs codes, a useless number.g41 is old intel chip set, 3.2GB max DDR memoryno model mobo told./ at all (sticker labels not told)no answers easy butfoxconnchannel.com is dead, now, 2012 it died.ended DIY support, we guess for ever, dead 10 years.drives for what OS, not told, xp,vista,w7 or w8?windows 7 sure.,. linux?drivers are a 3 way match.the MOBO and its chip sets , vast,The OEM makers, supportand the OS.all three must match, unless using USB or VIDEO cardsbut no OS told at all.The G41 can run w10 is some rare cases. (best CPU there)2010 or newer PCs or mobo are best not old.G41 is a 2008 chip.the VGA chip there is unknown not telling real mobo model,nor if using a GPU card, VGA.?they used many then. sorry can not guess mobo models me.
5/13/2022 12:52:42 PM •
Foxconn...
Answered
on May 13, 2022
Foxconn n15235 front panel jumpers
n15235 is not a model number everthat is an Australian, electrical safety compliance code. and 100% useless .foxconnchannel went dead 2012. they stopped dead DIY mobo sales, and the wiki said so too.the manuals are all lost now./ but googling finds some. but no model told, no JOY.lost the CD too , new in the box it had one, with PDF on CDlost that?, yes, ouch./or get the real foxconn, model number mobothe google that and add the word manualand bingo all jumpers told. some foxconn mobo are called contract OEM mobothe top makers of OEM PC ordered those custom and put them in their PC and the only clue is the lack of any DIY foxconn model on the board at all.that n15235 is NOT IT.learn to post photos of the mobo and all labels there.
5/13/2022 11:55:54 AM •
Foxconn...
Answered
on May 13, 2022
Pc h57m01a1-1.1-8eks3h
some boards are out of OEM PCs like gateways or the like
others were sold as DIY from foxconn direct sales.
did you lose the PC case?
or buy just a mobo , raw?
front panel pinouts you meant but failed to say just what:?
foxconn (channel) went dead. 2012
the maunuls where there, then, and now all gone. they are gone.
all is gone but the echo, (waybackmachine)
old
Intel P55 / H57 chipset
age ,2009, and lost manuals, are are not, lost 2012 year when the went dead.
no can find, me....
5/13/2022 11:50:16 AM •
Foxconn...
Answered
on May 13, 2022
Foxconn 2ABF Motherboard
you forgot the question1: need the manual ,a1, GOOGLE FOR IT2: NEED DRIVERS. WELL MAKER TOOK DOWN THERE DIY SITE.3: OR ?????????????their web site was taken down for all legacy DIY mobo .the exited the DIY businesstry buying only Asus.com mobo and only 2010 and newerTHE MOBO IS GOODIT IS Intel H61 BASED, I3 GEN2 UP, EVEN I7-2XXXRealtek ALC656 – High DefinitionHERE IS RETRO SITEhttps://theretroweb.com/hardware/motherboards/hp-foxconn-cupertino2W10 RUN ON THIS MOBO, SOUND MIGHT FAIL BUT IS EASY FIX. ASK
1/11/2022 3:11:39 PM •
Foxconn...
Answered
on Jan 11, 2022
Bios detection
DON'T OR SAY WHY YOU MUST?
99.9^% DON'T
OR BRICK LIKE MILLIONS HAVE NOW.
today is foxconn day;. and they went EOL , DYI in 2019
no PC told so is a vacuum of answers.
1/9/2022 11:41:32 PM •
Foxconn...
Answered
on Jan 09, 2022
