20 Most Recent
Foxconn 6627MA-RS2H Motherboard Questions & Answers
Where can i get the manual for the winfast motherboard n15235 ?
there is no such mobo, n15235, ever, that is electrical cert code for Australiayes bingo this: Foxconn 6627MA-RS2H ???>????and foxconnchannel.com went dead 2012. for DIY MoBo.winfast is product line that sells foxconn too but is dead also.....double dead.and triple dead if our unstated OS does not support this relic chip sets./Foxconn 6627MA-RS2H (real name this is) 2006 made.next time buy ASUS, and win, ok/?the echo of the manual is there, lucky you. free too.
https://www.manualsdir.com/manuals/768416/foxconn-6627ma-rs2h.html?page=2Pentium D is max best. herethe bad news is this lame chip not supported now.SiS662 (North Bridge) + SiS966L(South Bridge)966 is at vista max. 662 is ends at XP 32bit.and 64b it.RIP 662 , but some linux is supported. seen here/no SSL certs but is ok there.. they ended support so did not go SSL is why and costly.http://w3.sis.com/download/its nice they still pay for this domain, shocking that.so is this correct Foxconn 6627MA-RS2H many folks post here using wrong mobo modeldid you?n15235<<< and this is 100% USELESS max.
5/30/2022 11:38:22 AM •
Foxconn...
Answered
on May 30, 2022
Overclocking settings foxconn 662 7ma bios phoenix technologies version 6.00 chipset sis 662 intel celeron 331
there is no answer to that. no 2 CPUs on earth overclock the same amount nor way.
best is not OC< and learn to just compute and be happy?
old chips sets are 4GB max ram and useable to 3.2GB
the data sheet on your PC, for the north bridge tells you that
it PCI devices, or iGPU can steal RAM from main, to form up. vRAM
it even says the word steals. (intel pages)
find OC forum real and read. 1billion words to nowhere fast.
have fun with BSOD , endless. and random or hard worked hot.
5/13/2022 11:27:50 AM •
Foxconn...
Answered
on May 13, 2022
Audio wiring foxcom n15235
n15235, useless this.that is electrical certs numbertop of mobo has stickers only THEY matter.but sorry if is Foxconn 6627MA-RS2H (2007 made) SiS 662 Pentium D / Pentium 4 HT / Celeron D DDR2 667bad news SIS is dead now and so is foxconn diy mobo support by them 2019 they ended DIY kit business.you need the Audio port jacks from the front panelnot the rear that is a standard, green is output. end story there, pink mic. etc.you lost the CD out of the new box I see, so lost the PDF manual there too, ouch.then answer for pin header, markedAudio Interface: F_AUDIOis herehttps://manualmachine.com/foxconn/6627mars2h/1611735-user-manual/Audio Interface: F_AUDIOFor 6-Channel (optional)The audio interface provides two kinds of audio output choices: the Front Audio, the Rear Audio. Their priority is sequenced from high to low (Front Audio to Rear Audio). If headphones are plugged into the front panel of the chassis (using the Front Audio), then the Line-out (Rear Audio) on the rear panel will go offline. If you do not want to use the Front Audio, pin 5 and 6, pin9 and 10 must be shorted, and then the signal will be sent to the rear audio port.see graphic of jack same page.
5/11/2022 1:53:23 PM •
Foxconn...
Answered
on May 11, 2022
Acer n15235 lan driver
2006 MOBO DAY1. SOLD ON LINE FOR 100X VALUE TRUE OF $1NO PC TOLD AT ALL JUST OLD fOXCONN, OUT OF ACER ? PC?NO OS TOLD AT ALL, AND DRIVER ONLY WORK ON 1 VERSION OF OSNO OS TOLD SO ANSWERS ARE HARD OR WAY WAY TOO LONG.N15235 (checkmar.) is not a model number at all, (top sticker labels are)N15~ is the electrical safety certification , outside USA.learn to read the correct labels or get no where fast.10/100 M LAN SiS CHIPS HERE ARE DOA, ZERO SUPPORT ABOVE XP OR VISTA.OEM ENDED THAT SIS IS DEAD. PRODUCT LINE NOW. ever.see how here, both classes of FOXconn,DIY and OEMSupport ended in 2019 DIY.Acer Veriton M221 RS740M03A1-8KSDH label is between x16 slot and DRAM slot.white sticker.that is a contract mobo to Acer FROM FOXCONNAND IS a secret that contract as most are.and was removed from the PC and sold only for that Acer PCand the rear jack port (25pins LPT) has sticker thereand is Acer part number, EAnnnnnnnnnnand this tag.or learn what chip is LAn (ETHERNET ) IS ON THE 966SiS662 (North Bridge) + SiS966L(South Bridge)DEAD , DEAD AND EOL GONE FOR EVER. ZERO SUPPORT UNLESS RUNNING XP IS FUN, NOT, IT IS A VIRUS MAGNET.
5/11/2022 1:53:04 PM •
Foxconn...
Answered
on May 11, 2022
I am trying to install
out or RANGE means newer PC sending illegall(sic) resolution video to a very old relic junk MONITOR 2001? that old, not old.
set the PC to safe mode or set video reso to 800.x600 first then work higher.
bios video should work, just it.
same answer for 4 decades.
that is normal inserting GPU shuts off local igPU.
i bios under video see local, PCI , auto settings
set it as you want. local is IGPU
N14235 means nothing at all it is code number for elecrical certifications all MOBO sold for year other countries, not uSA.
SIS chip is trash now EOL no support ever now.
2007 made, pure trash, now. unless running old versions of linux.
there is no manual for this mobo, now, rare and old
google is your only friend, learn to read only white stickers on top of mobo to learn real model number or OEM numbers.
1/4/2022 5:53:00 PM •
Foxconn...
Answered
on Jan 04, 2022
Driver foxconn n15235
n15235 is not the motherboard model.
Look between the cpu and the mem on a white label. The model number is under the barcode.
6/22/2019 5:44:59 PM •
Foxconn...
Answered
on Jun 22, 2019
Characteristics of n15235 manual motherboard
- IntelĀ® Pentium D, PentiumĀ® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool:
http://tinyurl.com/n8nrz6t.
regards
1/7/2015 2:12:35 AM •
Foxconn...
Answered
on Jan 07, 2015
Necesito resetear la motherboard
Hola,
Bueno, lo unico que puedes resetear el el BIOS. Hay tres maneras de hacerlo.
- Prende la computadora, entra al BIOS y escoje "load defaults"
- Sacar la bateria redonda de la placa madre
- cerca de la bateria por lo general hay un "jumper" para cruzar dos patitas y resetear el BIOS
4/8/2014 2:29:50 AM •
Foxconn...
Answered
on Apr 08, 2014
