20 Most Recent
Panasonic NN-H264 Microwave Oven Questions & Answers
Changing the light bulb
Hi,# 1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.# 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.# 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.# 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.# 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.# 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.Regards.
1/5/2012 10:19:52 AM •
Panasonic...
Answered
on Jan 05, 2012
Oven only runs for 5 seconds no matter the time
I would need your full model number to help you best, but I'm guessing that at least it's a Panasonic?See if this describes
what's happening:
- Put
in time, push start and unit runs
for 2 seconds, relay clicks, unit goes off. Cook time on display goes
off and clock time comes back. Bad upper interlock switch and charred
connector
If so, see
http://031d26d.namesecurehost.com/mwd/safety.txthttp://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if
the digital programmer circuit / controller does not get a feedback
signal from the inverter for a period of 3 seconds, the controller will
stop the cook cycle.
It may be a loose connection in the wiring between the
inverter, magnetron, and/or control board, or maybe one of
those
components has failed.
Due to the lethal
voltages used and produced in inverters, I do not recommend that an
inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please create a new post with your brand and model number so we can help you.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
10/18/2011 5:33:07 AM •
Panasonic...
Answered
on Oct 18, 2011
Does not operate at all.
The first most posible cause is the fuse inside is blown if the power supply is ok. You can remove the cover of the oven, and look inside at fuse. You can test power supply / inverter with a voltmeter to see if there is power to the main circuit board. Take care not touching the capacitor since is full of deadly high voltage
7/26/2011 2:10:47 PM •
Panasonic...
Answered
on Jul 26, 2011
Code H97 on panasonice inverter
H97, mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these. Thanks, Midwest-tek
8/31/2010 11:25:12 PM •
Panasonic...
Answered
on Aug 31, 2010
Power to microwave but does not cook food
You didn't mention your brand or model number, but I'll assume it's a
Panasonic since you posted this under a Panasonic category.
what's happening:
- Put
connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if
If
it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16
seconds and is a sensor model, it probably has a defective humidity
sensor.
If
it stops after 22 seconds, that means the controller has detected a
problem, usually a problem with the inverter,
controller, magnetron, or a bad connection from one or the
other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the
those
Due to the lethal
We're
5/28/2010 1:23:11 PM •
Panasonic...
Answered
on May 28, 2010
No power
Either the fuse inside is blown, or the power supply is shot. You can remove the cover of the oven, and look inside at fuse. You can test power supply / inverter with a voltmeter to see if there is power to the main circuit board.
5/11/2010 11:37:50 PM •
Panasonic...
Answered
on May 11, 2010
Complete but temporary death
First unplug the mic
-Take down the mic
-Remove the three screws holding the plastic exhaust grill (the grill that exhausts air in to house... located front and top)
-Remove the two screws that hold the keypad
-Grab hold of the keypad and push up, then pull out.
-With the keypad out of the way look inside the mic you should see the 18v cylindrical ceramic fuse.
-Remove fuse, set meter to ohms and there should be no reading if the fuse is open (open means blown) if there is a reading it isn't the fuse... ???
-Reinstall new fuse... a 120v - 20amp fuse will do if you can find the original 120v - 18amp.
Smiles :-)
Robin Koykka
2/20/2010 12:00:28 AM •
Panasonic...
Answered
on Feb 20, 2010
