20 Most Recent
The Learning Company Zoombinis Logical Journey (480593) for Mac, PC Questions & Answers
How can install zoombinis on window 7
You should navigate to the setup file on the disc, right click, select 'Properties', choose the 'Compatibility' tab, select the 'Run in compatibility mode for:' checkbox, select 'Windows 98/Windows ME'. Then run the setup program.Alternatively, you could right click on the setup file and choose the 'Troubleshoot Compatibility' option.The problem here is that you likely have Windows 7 x64 which has little support for 16 bit programs. You may be able to run your program in Windows Virtual PC (XP mode) if you installed it, but the program will likely run rather slowly.If the solutions I have provided do not work, then I hate to say this, but you are out of luck.
Zoombini's Logical Journey won't start up
If the program produces an error right after hitting the Play button, I had success by launching the file Zoombinis Logical Journey.exe in compatability mode using Window 98 / ME and 640 x 480 resolution. The shortcut that is created during install points to TLCRUN.EXE which was what caused my error.
I put the disc in.
Hi anderswang92
It depends on your OS'es version . The fdriver doesn't run anymore under the most recent Mac and Windows versions .
Best regards ,
fanaudi .
When im starting the game, it says unable to
it means your game does not support your current graphic card, you have to install a additional graphic card, go to the your nearest computer shop tell about your game they will suggest you which graphic card is suitable for your game.
I recently upgraded windows vista to windows 7. i
well, i thought that windows 7 would have been developed to be compatible with ALL of the previous systems and programs that they were compatible with. as it is, windows 7 DOES have a way in the control panel that helped me out... there's actually a link in the control panel called "run programs made for previous versions of windows" it took a few tries to get the right setup for the game, but it's pretty self explanatory. sometimes it takes a couple of tries to start it up, but now i CAN play Zoombinis on my windows 7 pc.
