20 Most Recent GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Questions & Answers
Wash machine water issues
pull the hot water hose off at the faucet and machine and check for blockage in the hot water hose,clean or replace the hose sediment screens,then hook back up to water faucet and flush hose with hot water,then check water valve on machine for a screen and clean it as well before reconnecting hot water hose
4/28/2013 1:14:29 PM • GE WSM2480DWW... • Answered on Apr 28, 2013
0answers
Wsm2700dawww
Be the first to answer 3/25/2013 7:55:30 PM • GE WSM2480DWW... • Posted on Mar 25, 2013Be the first to answer
Kenmore he5 dryer won't heat up
What is the model number of your unit?
11/20/2012 10:31:37 PM • GE WSM2480DWW... • Answered on Nov 20, 2012
Washer will not drain
If it is not draining this could be due to two a few reasons. First is probably a fuse that runs the pump. Second could be a switch that makes the drum spin. I would try the fuse first. It should be in the wiring diagram inside the cover of the washing machine. I usually have to buy these fuses at automotive stores. You must take the cover that surrounds the drum of the washer and follow the wiring diagram but the fuse should be on the lower left I believe.
11/17/2012 5:14:36 PM • GE WSM2480DWW... • Answered on Nov 17, 2012
Dryer has cold air
You might need to replace the heater coil or coils....I had to do that on a previous dryer.
9/21/2012 6:01:52 PM • GE WSM2480DWW... • Answered on Sep 21, 2012
Wsm2700dawww dryer will spin laundry still wet
Possible that the speed is of the spin is not enough, check the belt , check for friction to the shaft in the washer.finally check the drain valve /pump as if there is water logged on without flushing then the valve is clogged or dirty.
8/24/2012 6:27:46 AM • GE WSM2480DWW... • Answered on Aug 24, 2012
Dryer not getting hot dryer spins but no heat
clean out the vent that the alumenum hose gos to
9/18/2011 5:20:40 AM • GE WSM2480DWW... • Answered on Sep 18, 2011
Washer wont drain or spin. Thewasher will agitate.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
8/25/2011 2:02:56 AM • GE WSM2480DWW... • Answered on Aug 25, 2011
0answers
2answers
GE WSM2700DAWWW dryer squeaks
When the felt on the front tub guides wears off it will squeak. It can be replaced by part 1220 and 1221 on this diagram and parts list. Take off the front panel along with the door to access it.
There is a ball and socket bearing at the back of the drum but it doesn't usually go bad. If you need to get to it, go in from the rear of the dryer behind the heat coils. 1212 is the bearing housing.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5221980&diagram_id=22300825#d22300825
8/20/2010 4:11:05 PM • GE WSM2480DWW... • Answered on Aug 20, 2010
0answers
Water is not draining?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
5/31/2010 4:17:29 AM • GE WSM2480DWW... • Answered on May 31, 2010
New washer draining out while washing or rinshing
If this is a brand new unit, make sure that the drain hose is hooked up at a level at or above the level of the tub. If it is too low, it can siphon the tub of water.
4/30/2010 3:53:41 AM • GE WSM2480DWW... • Answered on Apr 30, 2010
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
76 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
remove front panel ge spacemaker
  • Washing Machines
