20 Most Recent
Microsoft ChiMei CMV938D 19" Widescreen LCD Monitor Questions & Answers
Facebook is blocked in my office...
try to Change http:// to https://like this :http://www.facebook.com change to https://www.facebook.comyou will ask for trusting that certificate.just yes.https is secure website protocol.if that still not working, change www.facebook.com to 69.171.224.13like this :https://69.171.224.1369.171.224.13 is IP Address facebook.
Acebook is blocked in my office...
This is a protection by the authority concerned to keep the staff from using facebook when involved in work. The facebook site will be blocked on the main server and so it will not be available for viewing.
Chimei Monitor
my monitor chimei tco3 is black and will not show sceen
Sound now not working on
have you try to use headphone or other speaker except on the built-in speaker of your LCD?, if the sound still not working then re-install the sound driver of your motherboard.
Thanks
Need driver
Try this site i always get my drivers from this site www.driverguide.com its one of the best driverdownloads site i've known for awhile.
Can't reset the monitor settings. It's is
You will never reset your monitor updating your monitor driver. There is buttons on it check your manual. And of course never forget to update your videocard drivers.
I have a 19" cmv
How old is it? If it still under warranty get it repaired, it sounds like the switch is gone or the energy saving s/w inside is bad and is not detecting when/when not to turn the display on/off.
Monitor driver
you can set a resolution of 1440*900..
option 1) open device manager,, update the drivers for standard vga card.. locate ur video drivers folder,,(do it manually even if u have it on cd)...
option 2) this one is bit risky.... open add new hardware wizard and add ur correct video adapter, no matter ur standard display adapter is already installed. after you finish, update ur original standard display adapter and this time, it will pick the correct drivers.. now you can remove your dumb display adapter and restar pc .
risk is- be very careful, u dont want to remove your physical adapter by mistake, resulting no video after a restart.
when community sites such as facebook and proxy re-routings are blocked by your employer, this means that you are not supposed to go there during working hours. FixYa is a support forum, not a site for aspiring hackers... please direct you question elsewhere
LCD SCREEN STAYS BLACK
Get a quotation on how much it will cost to repair according to where u live... if it's 10 to 20% the LCD, so get it fixed otherwise ...
Sometimes bad capacitors can cause these probs
