20 Most Recent NEC ND-6650A DVD RW Dual Layer Burner Questions & Answers
0answers
IT IS A NEC 6650A
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary in left panel extend the events there you will see errors in red right panel you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem until you know what type of error it is you cant find a fix for the problem also you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps you
9/8/2011 10:13:24 PM • NEC ND-6650A DVD... • Answered on Sep 08, 2011
My drive cannot play any kind of disc, insert disc
There could be a lot of reasons why your drive is not working properly. It could be that there is a service from your burning software that is not running properly thus affecting the CD-ROM. If you have any of these software, try un-installing them.
You can also try this for an automated fix from microsoft.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Read and follow the instructions.
Hope this helps.
6/30/2011 7:49:56 AM • NEC ND-6650A DVD... • Answered on Jun 30, 2011
tip
How resolve issues with your Optical Drive that does read or write CDs or DVDs
This is a bit complicated so we have to be very careful in doing so. The main goal that we have is to Delete the Upper and Lower Filters on your registry, and that's what makes it complicated.
To start with
>Click on START
>Type REGEDIT on the search bar on START Menu
>Expand HKEY_LOCAL_MACHINE
>Expand SYSTEM
>Expand CurrentControlSet
>Expand Control
>Expand Class
>Click {4D36E965-E325-11CE-BFC1-08002BE10318}
>Look for the Upper Filters / right click on it / click on Delete
>Look for the Lower Filters / right click on it / click on Delete
>Restart computer
>Try you CD / DVD ROM
I hope it helped you out. Rating my assistance will greatly be appreciated. Should you have any followup questions feel free to post it here and I always get back to my resolutions. Thank you for choosing FixYa! Have a good one.
I'm using a Dell Inspiron
how long is the whole process of burning the dual layer dvd's
your computers hard drive might be getting to hot
try blowing out all of the dust from your laptop computers keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines. dust causes static which causes lots of unforseen problems with a computer and its parts also you might buy a laptop usb 3 fan cooler pad just to keep things cool/er you might check the leads ((motherboard to hard drive)) they might be bad/faulty hope this helps
3/7/2011 11:24:03 AM • NEC ND-6650A DVD... • Answered on Mar 07, 2011
My drive is disabled and I don't know how to
Do you find the green light glow if you press the eject button ? If No, First step is to Turn off the PC and disconnect the power cable from wall outlet and you will have to open the CPU Tower Cover and check the cables and firmly connect them again. this must be because of loose connection. Do Not attempt to do this if you are minor and for others, Do it at your own risk if you can.
Regards,
Ron
2/23/2011 12:28:34 AM • NEC ND-6650A DVD... • Answered on Feb 23, 2011
My burner will not burn
The CD Burner / Player / DVD Burner are all different heads. If the Dell Inspiron E1705 is an older model it is most likely you have reached the end of it's usable life for the CD burner part. If it is new the CD burner is most likely defective and hopefully warrantied. Otherwise these CD/DVD units can be replaced relatively inexpensively (as compared to buying a new laptop).
2/1/2011 4:27:14 PM • NEC ND-6650A DVD... • Answered on Feb 01, 2011
Hello I have a NEC
yes this should do DVD and DVD-RW disks as well as normal CD's and CD-RW's hope this helps
1/13/2011 9:50:55 AM • NEC ND-6650A DVD... • Answered on Jan 13, 2011
Can not burn CD. Error message from Roxi assistant
Not sure, but a generic test is try using a different blank CD, preferably a different brand. Also try same CD same brand on different burner.
4/3/2010 8:16:22 PM • NEC ND-6650A DVD... • Answered on Apr 03, 2010
IS IT A DUAL LAYER BURNER ??? MY NEC DVD + RW 1100 A
I am sadly having to tell you NO it doesn't WRITE to dual layer. It reads dual layer though and this is a good thing.
Best of it
3/29/2010 10:21:13 AM • NEC ND-6650A DVD... • Answered on Mar 29, 2010
The drivers say having no issues but when I place
What type of CDs/DVDs have you tried?
You can also try to reseat the cable of the CD drive inside the CPU.
IF you're familiar on how to use the Registry Editor you can try this solution:
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type regedit in the Start Search box, and then click regedit in the Programs list.
    Collapse this imageExpand this imagesecurityshield.jpg If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Note After you remove the UpperFilters registry entry and the LowerFilters registry entry, you may lose functionality in certain programs such as CD recording programs. In this scenario, you must reinstall any affected programs. If the problem recurs, contact the program vendor to determine whether an update is available for the program.
For information about your hardware manufacturer, visit the following Web site: http://support.microsoft.com/gp/vendors/en-us (http://support.microsoft.com/gp/vendors/en-us)
2/22/2010 5:55:23 PM • NEC ND-6650A DVD... • Answered on Feb 22, 2010
2answers
Cannot burn on DVD+R
pls check if ur burner suports dvd+R
Best regards
2/21/2010 4:37:25 PM • NEC ND-6650A DVD... • Answered on Feb 21, 2010
My NEC-6650A DVD RW (on Dell Inspiron 6000) won't read DVD ROM
mine does just the opposite. It will read DVD-ROM Games but it wont read data discs or DVD Movies.
1/27/2010 9:01:15 PM • NEC ND-6650A DVD... • Answered on Jan 27, 2010
Nec dvd+-rw nd-6650a stop burning dvds
It's time to replace the defective (and probably warranty-expired) unit.
If your computer is a notebook, not a desktop, it's best to take the computer to a qualified technician, to disassemble your computer, and replace the drive.
1/2/2010 8:31:48 AM • NEC ND-6650A DVD... • Answered on Jan 02, 2010
I have two Dell Latitude
You go back to device manager then right click the Drive and select properties and then check what is the error code there and if its error code39 you can use the steps from this link to correct this registry problem that you have with it
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
11/4/2009 3:48:23 AM • NEC ND-6650A DVD... • Answered on Nov 04, 2009
2answers
This message of calibration error
What burning tools have you use there. Try to use a NEro install it and use it to burn your disk, let me know
10/20/2009 3:07:40 PM • NEC ND-6650A DVD... • Answered on Oct 20, 2009
NEC DVD +RW - 6650A will not read a blank DVD
i ran into this problem a while ago. I had to test different dvd's. I then looked on the manufacturer's website. there they stated which dvd-r, dvd-rw would work. once i tried that brand It worked fine.
9/12/2009 8:59:50 PM • NEC ND-6650A DVD... • Answered on Sep 12, 2009
Ip address
No. Formatting your PC will not change your IP Address if it is set to automatically obtain it. Your router's DHCP server will allocate the same IP Address your computer is using.
4/2/2009 10:28:49 AM • NEC ND-6650A DVD... • Answered on Apr 02, 2009
NEC ND-6650A DVD RW Dual Layer Burner Logo
Popular Tags
43 questions posted
Top NEC Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ND NEC
  • ND NEC
Most Popular Question
  • Computers & Internet
