20 Most Recent
NEC ND-2500A DVD±RW Burner Questions & Answers
I have the DVD but
you could get this on Ebay
if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal
login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration
password ,bank card /credit card,phone numbers home/mobile ,email adress
and a postal adress
be very specific when you
type in the search
always ask questions?
before you make a purchase and keep the email/s for security reasons if the
item arrives and its not as described
you will even see the
pictures of your item so you cant make a mistake and get them home delivered
hope this helps
My nec nd-2500a cannot read
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.hope this helps
Nec 2500a dvd wont burn maxwell 16x dvd-r
It could be a firmware problem, you can update your firmware but be sure to update to the latest official, stable version. If you have problems only with this type of media and all others are OK, I would recommend you to use different media.
: "WRITER ERROR [ILLEGAL REQUEST (LOGICAL BLOCK
You could try and uninstall the drive in device manager, then let the pc reinstall the drive.
Try some other software, i use IMGBURN and CDBurnerXP.
Get back if this does not fix your problem
I only can write with 4x maximum while dvd could
DVD burners will only write to the maximum stated.
Also if you are using 4x DVDs then that is all they will burn at without often giving errors when used.
Trying to burn a 4x DVD at lets say 16x can cause burn failure or data corruption.
Cd's on the other hand can burn at lower speeds than they are stated.
To burn DVDs at higher speeds your burner needs to be capable of that speed
Suddenly stopped reading cds but reads dvds
Could be a bad drive, as DVD lasers are a little different than just CD lasers. The laser may be bad for one, but the other can work. I had this issue, had to buy a new drive.
Cannot burn Memorex DVD-R 16x
I hate being so simple on these questions, but these problems are always a process of elimination. First thing you always do in situations like this - try another brand of disc. Good luck!
DVD Burning Problem
To reinstall the driver RIGHT Click on My Computer - select Properties - select Device Manager - RIGHT Click the DVD listing - select Update Driver (have your disk handy).
Good luck.
DVD Writer problems
I used the drivers provided by windows XP. What do you mean when you ask about the configuration of my computer?
Burning
could you provide more info? the model number of the drive for exmaple. are you sure your using rewriteable DVD's? sorry to point out the obvious but id kick myself if i didnt check. Also you can goto the manufactuers website and if there is a firmware upgrade for your model of DVD writer.
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
- Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
- Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
- Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
- Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
