20 Most Recent NetGear WPN111 RangeMax Wireless USB 2.0 Adapter: WPN111NA (NTUSNGWPN111) Questions & Answers
2answers
I can't find my wep key.
WEP key you set up on your own in router configuration/setup.
Cheers,
Mike
Leave rate if I helped you, thanks!
6/29/2013 2:44:02 PM • NetGear WPN111... • Answered on Jun 29, 2013
2answers
When I open the network wizard it automatically
Try disabling the Windows Driver, so that it doesn't stomp on it.
12/18/2011 1:15:07 AM • NetGear WPN111... • Answered on Dec 18, 2011
2answers
NETGEAR WPN111 Smart Wizard auto-shut down
Download the latest drivers, wpn111 3.0 from netgear website, install, restart, if problem persist;open control panel, add hardware, manually install the device drivers, usually the list it shows you has a yellow mark. After doing this you should be able to open and follow the instructions.I had the same problem and this it solved it.
12/18/2011 1:13:44 AM • NetGear WPN111... • Answered on Dec 18, 2011
Im trying to connect with
Hello subaikri,
I've given you a "Link to the Website, where you can,
"Download the Drivers / Software, that you need."
First, make sure that the you choose the other than; if not -> Windows 7?
**{New Drivers / Software"}!
"All other apply to "Vista!" e.g: WPN111 Software Release Version 2.1...
Scroll-down the (page), until you see the "Software."
There will be a {List}, to choose from!
This way, you'll be able to get the right "Drivers / Software."
Next, download the [File].
Find the {File, and "Install the Driver / Software"}.
"Restart the computer, so that the configuration can make the 'correct' changes.
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Click here for "Drivers"
http://support.netgear.com/app/products/model/a_id/2620
8/17/2011 9:15:09 PM • NetGear WPN111... • Answered on Aug 17, 2011
Over heat for netgear
For that over heat netgear wifi try connect other USB ports of your desktop or laptop.observe again.maybe over volts come out.
5/28/2011 6:11:52 AM • NetGear WPN111... • Answered on May 28, 2011
Poor connection strength
Sometimes you will get a false low signal strength indication, but here's something to try anyways.
Imagine if we lived in a society where all TV signals came in on the same channels.
If you are watching channel 11, but 3 other tv stations are broadcasting along with the one you want to watch, it takes a lot more effort to get the information you want from the one station you are trying to watch.
So lets say you and your tv station strike up a deal, and they move to channel 6...and nobody else in the area is on channel 6...great, now you can watch your program effortlessly.
Wireless can be like that, and most routers are factory configured to channel 11.
Look in your router manual or pdf guide or whatever instructions you have for it, and change the wireless channel.
I have found in the past that you can go from poor signal with frequent disconnects, to full signal strength at the highest speed and no disconnects, just by choosing a better channel (and yes, I usually pick 6 first, and only try others if necessary).
2/27/2011 1:26:23 AM • NetGear WPN111... • Answered on Feb 27, 2011
Have install netgear range booster
This can occur when the wireless adapter has trouble connecting to the wireless router.
It may not get an IP address from the router or the wireless adapter encryption setting didn't get an the encryption authentication from the router.
In this case right click on the wireless adapter on the Task bar and click Repair. This will make the router re-issue an IP address and authenticate the adapter's encryption setting.
2/19/2011 7:09:24 AM • NetGear WPN111... • Answered on Feb 19, 2011
Can I use my wpn111 with my 2wire wirless modem
As i know yes you can.Just do the setup and post back any problems.
1/4/2011 9:32:11 PM • NetGear WPN111... • Answered on Jan 04, 2011
Can i use a Netgear
No definitely not....
If you want your Xbox to be wireless, then you need to buy Xbox wireless adapter...
Bcoz the Xbox wireless adapter comes with a pre-built in drivers....
but other brand wireless adapter donot comes with a built in drivers, you need to install the drivers using a driver cd....But Xbox do not allow driver cd's to be installed on it... so you will not be able to use ordinary wireless adapter instead of Xbox wifi adapter...
12/10/2010 7:42:19 AM • NetGear WPN111... • Answered on Dec 10, 2010
2answers
My Netgear wireless WPN111 keeps disconnecting me
Are you sure the problem is between your USB adapter and your router? I've had similar issues with my connection but the problem was with the router itself. I've downloaded a new version of the router firmware and everything has been fine since the upgrade.
9/27/2010 1:51:42 PM • NetGear WPN111... • Answered on Sep 27, 2010
I am running Windows Vista
Ventilation is the problem of your netgear wireless adapter losing signal when it gets hot, you will need to get a good place that the ventilation is cool and cold enough to help cool the adapter.
I work in an ISP company, anytime the our air conditionig in the server room breaks down, we experience bad internet services because the internet will either be very slow or not going at all, ll we use to do is to makesure the server i protected by getting a a standing fan standby near the server incse of the ac failure.
So, your case is very glaring to me that, the ventilation is the problem, you will need to get a cool or cold environment to work with your adapter, with this, it will never get hot and lose signal.
Take care.
6/13/2010 1:18:22 PM • NetGear WPN111... • Answered on Jun 13, 2010
I just got an emachine Et1331G-03w machine. I
do you have the install disc for te netgear router ?
you have to have one
6/7/2010 1:41:51 AM • NetGear WPN111... • Answered on Jun 07, 2010
Bought a NetGear WPN111 RangeMax Wireless USB 2.0
Hi
firstly you can try upgrading the drivers on the adapter. following is the link for the latest drivers http://kb.netgear.com/app/answers/detail/a_id/12520
If the problem still persists
try changing the wireless settings on the wireless router.
4/7/2010 9:02:41 PM • NetGear WPN111... • Answered on Apr 07, 2010
My usb wireless card is not recognizing the
Do the protocols match?
Did you install the drivers for the wireless card?
If they do and you did then the wireless card is no good.
3/27/2010 6:48:53 AM • NetGear WPN111... • Answered on Mar 27, 2010
I am trying to install the netgear wireless to my
please downlaod latest driver for adapter then install in computer
link for latest driver
regards
prakash
3/21/2010 3:04:32 AM • NetGear WPN111... • Answered on Mar 21, 2010
The software won't stay up after its been installed
it seems that driver is not install properly
1.reinstall CD or download latest driver from netgear website and install in computer
regards
prakash
3/19/2010 4:58:11 AM • NetGear WPN111... • Answered on Mar 19, 2010
I have a Netgear WPN11 smart wizard wireless
please download latest driver for adapter and install in computer
3/19/2010 3:23:29 AM • NetGear WPN111... • Answered on Mar 19, 2010
The wireless adapter WPN111 on Windows XP shows up
please download latest driver for this adapter and install in computer
http://kb.netgear.com/app/products/model/a_id/2620
3/19/2010 2:59:23 AM • NetGear WPN111... • Answered on Mar 19, 2010
LAPTOP D505 NOT AXCCEPT THE NETGEAR WPN111?
If the laptop cannot connect to the wireless router then the wireless card in the laptop has not been configured with the router's wireless settings.
To secure your wireless network, configure the wireless router and wireless card in the laptop, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
1/21/2010 8:05:33 AM • NetGear WPN111... • Answered on Jan 21, 2010
I have a Netgear WPN 111 dongle on a stand alone
As u have upgraded ur router setup ..
And u have tried all possible troubleshooting steps..
Please upgrade the adapter drivers using
And after upagrading the drivers ,
Uninstall the adapter and reinstall it ..
I hope it will be connected ..
1/16/2010 11:53:03 PM • NetGear WPN111... • Answered on Jan 16, 2010
Computers & Internet Logo
50 questions posted
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
RangeMax NetGear
  • RangeMax NetGear
Most Popular Question
netgear wpn111 smart wizard auto shut
  • Computers & Internet
