Lost or Unable to use Router Configuration CD
Problem:
var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
NETGEAR
does not replace lost or broken CDs because the Smart Wizard
installation and configuration utility on the CD is already built into
your router management software. There is no need to download anything
to replace the CD - everything you need is in your router. This is
true even if:
- the CD that shipped with the router has been lost or cannot be read, or
- errors occur when running the configuration program, or
- the router is not connected to a computer using the Windows operating system.
Workaround:
var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay);
To access the Smart Wizard installation and configuration program on your router:
- Connect your router to a computer by plugging one end of an
Ethernet Cable into any of the four LAN ports on the back of your
router.
- Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
- To install your router, simply click on the "Setup Wizard" link at
the top of the left-hand navigation menu once you are logged into your
router.
A video walk-through of installing and configuring your router using the Smart Wizard is available at
http://kb.netgear.com/app/answers/detail/a_id/12873.
