20 Most Recent
RCA 14F512T 14" TV Questions & Answers
My TV is making cracking noise
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
My tv says fpa lock
Hello
To unlock your rCA TV, try out the following methods. One amoung them will surely unlock your TV. NB: You must have its original remote handset to operate with these tricks.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you. - Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
- Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
- Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET OK.
I don't know how to put the tv on video
Tries pushes the tv manual button channel up a few times,tv will to go into the Video mode 1 or 2 for most of the analog tvs.Or look on the bottom front of the tv frame bazel for a manual buton said VIDEO.Pushes that manual VIDEO button to get in video modes 1 or 2.U have ur original remote have a button said INPUT pushes that button a few times to get into Video 1 or 2.
How do i get my tv off of fpa lock
Hello
Your TV has locked I thinks. Do the folloing and see if it works. This process can unlocka your RCA tv. You have to reset it V-chio after unlock.
- Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
- Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
- Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
- Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model the processs mentioned above may differ. You have to go all these, till your TV gets unlocked.
OK.
Can't change channels without remote
I don't know if you have child lock on your remote. If you do and it is turned on it will keep you from being able to change channels on your TV.
