20 Most Recent
HTC One V Questions & Answers
Htc one phone handset will not charge
Phones are very cheap now so just get a new one or reconditioned model.
If you don’t change phones then you will have this issue every 6 months. Some phones just do not last. Sure they are supposed to last 12 months but reality is different.
9/26/2017 7:49:31 PM •
HTC One V
Answered
on Sep 26, 2017
No service,pulling my hair out! Any ideas?
Just in case it isn't unlocked, you could use the first unlock link.
They do mention after inserting non-accepted SIM, being asked for code - are you getting this?
2nd may provide you a guide on how to connect - I don't have a phone to try with so no idea if it will help or not so I truly hope it does.
You may want to check out more of the links but these 2 appeared the most promising of a Google search off 'unlocked htc one v no service'.
1/10/2015 12:01:30 AM •
HTC One V
Answered
on Jan 10, 2015
What happens when I get a message saying "unfortunately HTC Sense Input has stopped"
Basically it's just letting you know for some reason, that program stopped but in the vast majority of cases, in a few seconds, it has restarted already. Now if you are getting that same message repeatedly (at least once a minute), then you may have a problem with it or something supporting or interfering with it.
Unless a phone system update just occurred before, a recently updated app could be the culprit.
12/18/2014 4:35:28 AM •
HTC One V
Answered
on Dec 18, 2014
My phone runs very slow, how do I fix this?
Have you tried resetting you phone to the factory defaults and starting again from stratch?
Alternatively, go to the application manager and uninstall any application that you have downloaded an no longer want.
10/19/2014 3:25:31 PM •
HTC One V
Answered
on Oct 19, 2014
Why is my htc one not recognized by usb?
Go to HTCs web site download HTC sync install it then plug in your phone if the prompt still doesn't come up go to control panel --> system --> device manager on your pc and look for a device with a yellow exclamation mark on it. Right click it choose uninstall after it finishes plug your phone back into your computer.
4/26/2014 2:36:09 PM •
HTC One V
Answered
on Apr 26, 2014
I bought the HTC second hand. I didn't know the
if you don't need any data in it, then just reset it:-turn it off- keep pressing Volume-Down button while powering it on until you see the recovery menu- choose reset and restart it
8/17/2013 10:30:54 AM •
HTC One V
Answered
on Aug 17, 2013
Htc one v no power, not charging
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
6/11/2013 1:17:25 PM •
HTC One V
Answered
on Jun 11, 2013
Need a manual book for a HTC One V
Hiyou may find the download and operating Video Links at the link below http://www.htc.com/in/help/htc-one-v/hope this helps Pavan
9/10/2012 8:30:07 PM •
HTC One V
Answered
on Sep 10, 2012
