20 Most Recent Holmes Products HM4600-U 11 Gallon Humidifier Questions & Answers
3answers
Holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
12/22/2014 4:29:27 AM • Holmes Products... • Answered on Dec 22, 2014
Need new rubber tank gasket
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700 woodinvirginia
2/13/2014 7:05:43 PM • Holmes Products... • Answered on Feb 13, 2014
What happens if the humidifier
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
2/2/2011 9:52:56 PM • Holmes Products... • Answered on Feb 02, 2011
3answers
Need Manual for Holmes Humidifier HM4600
because no one else posted the site, heres the pdf
http://www.appliancefactoryparts.com/content/pdfs/116674.pdf
5/17/2010 7:37:27 AM • Holmes Products... • Answered on May 17, 2010
Have been looking for just one of the tanks as the
you check at local hardware stores. or if your in canada check with canadian tire. if nobody has it locally. you might have to call the manufacturer to order it directly from them.
8/20/2009 10:36:32 PM • Holmes Products... • Answered on Aug 20, 2009
Holmes HM4600 Humidifier LEAKING - - HELP
well since you just purchased this item, you should be able to return it for exchange, and it should still be under warranty, but if thats not doable, then it sounds to me like its a O-ring that is bad if the tanks are removable, best bet though is to exchange it, look at your home owners paperwork, to see about the warranty, more than likely your covered, hope that helped,
mr.grzz
1/22/2009 6:12:49 PM • Holmes Products... • Answered on Jan 22, 2009
Waters tanks never empty
Either you have no wick/filters or they are installed incorrectly. Tanks should empty within hours.
1/16/2009 12:43:52 PM • Holmes Products... • Answered on Jan 16, 2009
How can I prevent mineral buildup in my small humidifier?
You really have an mineral problem. I have pretty much same here. I only use bottle water that comes in gallon size from grocery. Ot is the only way I have found other than constand cleaners or a water softener. Good luck
1/27/2015 10:13:15 AM • Holmes Products... • Answered on Jan 27, 2015
How can I get a humidifier instruction manuals
Go to http://www.holmesproducts.com/service-%26-support/product-support/instruction-manuals/humidifiers/humidifiers-manual.html and see if one of those listed will help you. The specific model HMS 250 seems to be out of print, but the current ones may help you with what you need to know. If not, contact them at https://www.holmesproducts.com/contactus?cid=contact-us and see if they will email you the correct one.
7/26/2014 5:19:33 PM • Holmes Products... • Answered on Jul 26, 2014
Why does my humidifier holmes 1700 blows air but no water or mist?
If the water has been sitting in the reservoir for days without use, it may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again. Good luck thebqe
5/6/2014 3:14:48 PM • Holmes Products... • Answered on May 06, 2014
0answers
0answers
Hm1280
Be the first to answer 2/11/2014 5:52:20 AM • Holmes Products... • Posted on Feb 11, 2014Be the first to answer
Holmes Products HM4600-U 11 Gallon Humidifier Logo
Popular Tags
18 questions posted
Top Holmes Products Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Holmes Products Humidifiers
Most Popular Question
need new rubber tank gasket
  • Humidifiers
