20 Most Recent Holmes Products HM500-UC 1 Gallon Humidifier Questions & Answers
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
Holmes Products... | Answered on Feb 16, 2015
The steam is condensing as it is expelled. The solution is to place a sheet of plastic underneath the unit to protect the surface
Holmes Products... | Answered on Jan 03, 2013
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Holmes Products... | Answered on Aug 26, 2011
Thatis a safety feature designed to avoid overheating due to being empty.
You need to reset it.
Unplug it for a few minutes, and then set it to reset, after plugging it in. It should be working after a few minutes.
Holmes Products... | Answered on Jan 31, 2010
If you can see the mist, then, it is working. The outlet
port of your humidifier could be closed/stucked up/clogged. Please check this the outlet port.
Holmes Products... | Answered on Jan 06, 2010
unfortunately running the unit for too long will permanently ruin the unit. there isn't really a way to fix it. i do deeply apologize for that. so unfortunately you might have to replace the unit.
Holmes Products... | Answered on Aug 29, 2009
i would try cleaning the coils for the heat portion. if they are to scally that could be one reason why it's not making any mist. but if it looks pretty clean or if you have cleaned it and it's still not making any mist then it's something internal. now if your under warranty still that's a good thing. you can always call the manufacturer and they can replace theunit for you under warranty . if you have any other questions please let me know.
Holmes Products... | Answered on Aug 21, 2009
You really have an mineral problem. I have pretty much same here. I only use bottle water that comes in gallon size from grocery. Ot is the only way I have found other than constand cleaners or a water softener. Good luck
Holmes Products... | Answered on Jan 27, 2015
Go to http://www.holmesproducts.com/service-%26-support/product-support/instruction-manuals/humidifiers/humidifiers-manual.html and see if one of those listed will help you. The specific model HMS 250 seems to be out of print, but the current ones may help you with what you need to know.
If not, contact them at https://www.holmesproducts.com/contactus?cid=contact-us and see if they will email you the correct one.
Holmes Products... | Answered on Jul 26, 2014
If the water has been sitting in the reservoir for days without use, it may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
Good luck
thebqe
Holmes Products... | Answered on May 06, 2014
Holmes Products HM500-UC 1 Gallon Humidifier Logo
Popular Tags
15 questions posted
Top Holmes Products Humidifiers Experts
Paul Carew
Dennis Webber
Marvin
Marvin
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
View Most Popular
  • Holmes Products Humidifiers
Most Popular Question
steam wets hardwood floor or carpet
  • Humidifiers
