20 Most Recent
Danby DKC645BLS Compact Beverage Cooler Questions & Answers
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Not cold enough
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded sometimes the error can be solved by simply disconnecting the molex plugs from the boards, straighting out the pins and reinstalling
