20 Most Recent
Fisher and Paykel Fisher&Paykel E522 Bottom Freezer Shallow Depth Refrigerator Questions & Answers
Fridge is freezing everything, i
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Take care.....
Hi, I have a Fisher and Paykel E402B
the defrost heater or thermostat located on the evaporator coil thats icing up isnt defrosting due to a bad heater or thermostat,or it can be the defrost timer that powers these other 2 parts
Fisher and Paykel fridge E521T is not cold enough?
If your Fisher and Paykel E521T fridge isn't cooling properly, check the temperature settings, clean the condenser coils, ensure proper ventilation around the fridge, and inspect the door seals for any leaks. If issues persist, consider contacting Fisher and Paykel customer support or a professional technician for assistance.
I moved a fisher and paykel upside down fridge freezer to a new house, I turned it on a half hour after it was in my new home but it has not gotten down to a cold enough temp, if I turned it on too so
It is possible damage will result. Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an hour is more than enough time.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
How do I fix a F2 Fault on my refrigerator - Fisher and Paykel Refrigerators
The F2 code on the active smart model relates to an EVAP SENSOR RESISTANCE FAULT which means the resistance of the Evaporator Sensor is outside of the normal range (> 45k ohms).
In the first instance
- Check sensor connection at the controller
but if that does not resolve the problem then the sensor would need replacing.
