20 Most Recent Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator Questions & Answers
4answers
Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
1/14/2023 10:14:17 PM • Fisher and... • Answered on Jan 14, 2023
0answers
0answers
We have a broken freezer basket. Where do we find a replacement
You will have to call fisher pay keel in Australia to get that information.
3/2/2014 5:25:06 AM • Fisher and... • Answered on Mar 02, 2014
0answers
Fault code 17
Be the first to answer 2/8/2014 3:02:16 AM • Fisher and... • Posted on Feb 08, 2014Be the first to answer
0answers
Tighten handle
Be the first to answer 10/16/2013 4:32:03 AM • Fisher and... • Posted on Oct 16, 2013Be the first to answer
0answers
3answers
Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
2/9/2013 12:17:10 AM • Fisher and... • Answered on Feb 09, 2013
Our FP refrigerator is about
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/8/2011 2:12:48 PM • Fisher and... • Answered on Aug 08, 2011
2answers
Temp indicator in both frig
Hi brianey,
The first thing to check when your refrigerator is not getting cold at all is the compressor. Since on your case it's running and the machine is not blowing cold air inside the freezer. You may have (1) a restriction inside the sealed system or (2) have a leak in the sealed system and all the Freon has escaped. Of course if there's no Freon no cool. And this is not a do it yourself job. You will need to contact a local repairman.
However there's another thing that you can check and you can do it yourself. Have your condenser coil be checked. Consider cleaning these first, they get dusty and hairy too specially if you have pets.The Condenser Coils on your Refrigerator is where the Freon gets put under pressure, therefore causing them to get warm. In order for your Refrigerator to run efficiently these coils need to be able to dissipate Cleaning the Condenser Coils the heat. If the coils are covered in Pet Hair or Dust, this will cause the sealed system to overheat. You may use a damp rag or lint brushes. Before doing any checking remember your safety.
Hope it helps.
Thank you for using FixYa.
5/7/2011 5:10:24 AM • Fisher and... • Answered on May 07, 2011
Help - the refrigerator (top) is not cold enough -
have you tried cleaning the coils.
3/7/2011 1:40:17 PM • Fisher and... • Answered on Mar 07, 2011
Wanting to disconnect buzzer that makes a noise
It's buzzing for a reason. Check your temps with a thermometer.
1/30/2011 3:54:22 AM • Fisher and... • Answered on Jan 30, 2011
Refrigerator section does not keep food cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101......................
12/27/2010 10:50:43 PM • Fisher and... • Answered on Dec 27, 2010
Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator Logo
47 questions posted
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Refrigerators
Most Popular Question
ice maker quit making ice
  • Refrigerators
