20 Most Recent
Abit KV-85 Motherboard Questions & Answers
Machine doesn't power up
Remove and reseat all memory, power and processor.
Check your power supply and if good check the board for bad Caps.
Manual for abit motherboard kv-85 and drivers
This is the best way to download the drivers of all your devices which are connected to the system for free.
You can download the Driver Magician from this link :
http://www.toggle.com/lv/group/view/kl34858/Driver_Magician.htm
Download the reg key from this link :
http://public.box.net/paul123
then doule click & select ok.
Run the program and select update drivers, it will list the list of pdated drivers.
Select the drivers and select download drivers.
If it does not download just select the driver you need and at the bottom you would see a link,
Just copy that link and download from your browser or download manager, I use orbit downloader.
or
You can also try this :
http://tinyurl.com/brslmb
Good Luck.
Live, Love, Luagh.
Vaio PCV-RX401 error COOD11BA
you might have a problem with the driver for the sound card, you need to install the driver or do a reinstallation of the sound driver
Sound doesnt work
make sure it is enabled in the bios
make sure the drivers you load are the correct ones
there are many realteck drivers around
hope this helps
Purchased Used
You can find the drivers needed for your motherboard here.
http://www.uabit.com/index.php?option=com_content&task=view&id=32&Itemid=48&page=4&category=3&subcategory=219&model=305&product_name=KV-85
Download everything listed on the page. You can burn it to a disc on a windows xp computer by right clicking on the files and selecting send to, then your cd burner.
I hope this has explained your question in detail. If I've helped you please don't forget to rate me.
Peter
How to connect 2 cd-roms to motheroard
If they use the wide ribbon cable, you need the cables with two connectors. Then set on drive to master and one to slave, or set both to CS - for cable select. When you restart the computer, the OS will do the rest.
Kds monitors support
Hi Klex,
I was able to find the website address
www.kdsusa.com through one of their products on Newegg, but the site appears to no longer exist. They also had a phone number listed (1-800-283-131) but that too doesn't seem to work. I have the feeling that they have either close their business or ended their operations in the U.S..
Sorry I didn't have better information for you.
