Abit IC7 Motherboard • Uploaded on Apr 06, 2014
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics card restart your computer reinstall it should activate found new hardware wizard
hope this helps you
32 questions posted
38 Questions
25 Questions
25 Questions
21 Questions
21 Questions
