20 Most Recent
Liquid Video E17LCD1 17" Flat Panel LCD Monitor Questions & Answers
There is a vertical line
hi matai,
sounds like the monitor may have physical problem with it, which is not practical to fix. To have a definite answer, switch do a different monitor if line is gone then you have your answer. However if the line shows up on a different monitor this is an issue with the graphics on the pc and will need to be replaced.
After about an hour of use today the power light
rcharby622, LCD monitor may need servicing of it's "switch-mode-power-supply/CCFL inverter supply to find the one (1) bad thermally intermittant component solder joint or have the BAD low or poor quality (short lifespan) electrolytic filter capacitors replaced on the units SMPS. Do some reading in my and other "cold-cathode-fluorescent-lamp back-lit lcd monitor technicians FIXYA PROFILES. Follow the "links" you find there. After doing your research, feel free to come back to this response and rate it on FIXYA. Bye for now 12fixlouie
Using a Liquid Video E19LCD1 Monitor as a TV
No tuner just a cable with the righg adapters on both sides. if you had a dvi connector out on the video card, you can get HD. Just go to
WWW.tigerdirect.com, or newegg.com, and order the connector to convert dvi to hdmi, or you can go vga ,component, or dvi whichever works for you the sat reciever is now your tuner, I did it for years on my office monitor, good luck, if you need more help just ask for me, I won't charge you anymore,
Gymowner
LCD blinking on and off continually
If it flashes ON and OFF when simultaneously unplugged from both power and the computer then it's trying to communicate with you.
Mine flashes code to me. It tells me what to do. Last night it told me to get it $5,000,000 in unmarked bills.
Seriously, turn the monitor on without connecting it to a computer.
If it flashes ON and OFF continously, then you have either a bad monitor or a bad AC/DC power adapter/brick (you know, the rectangular black corded adapter you plug into the wall outlet).
If it only flashes ON and OFF when connected to a computer, try the monitor on another computer.
If the monitor is 3-4 years old, it may be time to replace it since a replacement AC/DC adapter might be very hard to find.
Let me know what you find out, if you need more help.
ZT3000
"Beta tester of "0"s and "1's"
Need power cord
the best place to check would be circuit city (locally) or on E-Bay.
Hope this helps.
No power
Check the fuse, if that's OK check the wall socket works by plugging in something you know to work.
If the monitor has an external power brick check if it has any indicator lights and if they are on.
Horizontal
Hit the menu on your monitor than go to manual adjust and try to adjust if that doesn't work try to hit auto again if that doesn't work try to unplug both cables from monitor and plug it back again... let me know if that doesn't work I got more informations about this problem. Send an e-mail at
[email protected] for more solutions.
Plugged in and hit the
the outputs to the screen has grown weak A new screen is your choice purchase since they are cheaper to replace than repair
Looking for a new remote
there are several after market controllers available.
I assume you can't get an original controller from the manufacturer?
If not, these are many well known manufacturers of multi-system controllers:
OneForAll http://www.oneforall.com/
Logitech http://www.logitech.com/en-us/remotes/universal-remotes
I have both of these brands and I can control several electronic components from 1 controller rather than 4 to 6 separate controllers. Any electronics shop or hi-fi retailer can help. Ebay is a good place to look if you like buying online.
Here's something to get you started:
http://electronics.shop.ebay.com.au/Audio-/14969/i.html?_nkw=remote+control&_catref=1&_fln=1&_trksid=p3286.c0.m282Cheers, Steve
PS Please vote for my answer or give a testimonial if I have helped.
